  • July 12, 2025, 10:09:39 PM
Author Topic: Hot Stuff Super T - still the best  (Read 3820 times)
« on: April 20, 2014, 11:32:35 AM »
Keeping with my "glue thread" kick this morning, I found that the real McCoy "Hot Stuff" was still available, and got some. After using every brand (Zap, CG, the Bob Smith stuff that is relabeled for every hobby shop in the country), and then trying the real deal again after 20+ years, I still think that Hot Stuff Super T is still the best medium CA. It is a little thinner than the typical medium CA, and it takes longer to set that most. ZAP and CG can sometimes zap off in open faces before you want. Super T has yet to do that to me . It also seems to have a longer set sequence, so it will start to zap, spread a bit as a liquid, then finish.  It's about halfway between ZAP (and all others) "thin" and ZAP+ in terms of viscosity. It makes the joint coverage much more complete.
    It was remarkably better for joining wing skins and I did a bunch of 1/32 and .066 skins and it never once grabbed before I was able to make a final alignment. It's actually a little less than ideal for field repairs because you have to hold everything in place for substantially longer. But for controlled conditions it's much more pleasant to use.
    The Hot Stuff video could have been done at my house, I still use the same techniques and it still works fine as long as you use Super T. I have figured that since the Hunters are no longer in charge of the thing, someone bought a gallon drum of flourescent pink and yellow ink for the labels, and then bought the glue it from Bob Smith like everybody else. Apparently not, it's still different and still the best.
Offline James Mills
Re: Hot Stuff Super T - still the best
« Reply #1 on: April 20, 2014, 09:28:21 PM »
Brett,
I've never used Hot Stuff (I think that was before I joined the sport).  Where is it available?
James
AMA 491167
Offline Steve Fitton
« Reply #2 on: April 20, 2014, 10:09:01 PM »
where did you find fresh hot stuff?
« Reply #3 on: April 20, 2014, 10:45:50 PM »
« Reply #4 on: April 21, 2014, 08:15:41 AM »
https://granquartz.com/Pages/ItemClass_Catalog.aspx?search_val=hot+stuff&qsearch=&search_type=Product&class=&advanced=
I buy the same stuff here at work, we go through a couple gallons a year. I did not look at Brett's link so I cant say if Grandquartz is any cheaper than his supplier.
Derek
« Reply #5 on: April 21, 2014, 08:22:08 AM »
Well, I went and looked at Brett's link and it appears that the single bottles are a little cheaper at Grandquartz and the kit is a little cheaper at his place.
Derek
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
« Reply #6 on: April 21, 2014, 08:56:06 AM »
Woodcraft woodworking stores Cary it
Dave Siegler
NE9N extra class
AMA 720731
« Reply #7 on: April 21, 2014, 09:05:25 AM »
Yeah, the woodcraft stores here carry it, but I think it sits on the shelf a loooong time.
I puzzle over CA shelf life.  My understanding is even a sealed container is only good for a year ago, yet my Dad's 30 year old bottle of Eastman 910 still works. I get 6 months to a year from Zap.
 I would not have guessed at the manufacturer of Hot Stuff selling direct, so I'm glad Brett posted the link, even if it should have been obvious to everybody but me.
...and I guess we know where Derek gets his CA from ...! #^
« Reply #8 on: April 22, 2014, 07:36:07 PM »
  I get 1 oz bottles, and freeze it. The Hot Stuff bottle I am using now is about 5 years old, and was defrosted about a year ago.
« Reply #9 on: April 28, 2014, 07:07:11 AM »
I am not sure if you guys have tried the newer Aerosol activator that Hot Stuff sells but it is much better than the old spray bottle stuff.
Derek
Offline Allan Perret
  • Proverbs
« Reply #10 on: April 28, 2014, 07:36:02 AM »
Does activator make a CA joint stronger, or just set faster ?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #11 on: April 28, 2014, 08:33:36 AM »
Faster, which probably means weaker. Sometimes, if you are just trying to tack a piece in place, fast is good.
Derek
« Reply #12 on: April 28, 2014, 09:38:41 AM »
    It always seems to go off plenty fast enough for me even without kicker. One of the things I think is better about Super T is that it doesn't go off just sitting there on the surface waiting for assembly, or at least not as fast as many of the other types.
    The accelerated joints are generally much weaker. They tend to be a foam rather than a solid acrylic. But, if you are just gluing balsa to balsa, its probably still strong enough. I use accelerator only in very very rare occasions, like trying to glue spruce to spruce, or something like that where it doesn't want to go off otherwise.
« Reply #13 on: April 28, 2014, 10:24:32 AM »
We use a fair amount of accelerator at work setting seams with thin CA. I do not use if in modeling very often either but I have had cases where it helped. The benefit of the aerosol spray is that it atomizes the liquid much better than the old spray pump and this prevents the "white foam" that you mentioned. It obviously can be over applied and cause the same thing but in general, it works better.
Derek
« Reply #14 on: April 30, 2014, 03:29:13 PM »
Wouldn't an atomizer of just plain water set off CA?
« Reply #15 on: April 30, 2014, 08:22:30 PM »
A trick I learned as a luthier is to spray the accelerator on the area first, wipe it back off and wait several seconds before applying the CA.  It still sets more quickly but without the crystallizing or bubbling effect.
Contrary to most here, I've used nothing but Bob Smith adhesives for many years as i think it the best.
Offline Dave Harmon
« Reply #16 on: July 09, 2014, 10:43:51 PM »
A very fine spray of accelerator works best as someone said.
I found that the typical pumps sprayed droplets....just too much of the stuff....so I went to the drugstore or somewhere and got a couple of $1 trial size hairspray bottles.
Then I dumped the hairspray and washed out the bottles....now I got accelerator in one bottle and water to spray Jap tissue in the other bottle....cheap...works great.
While I am on a roll.......glue syringes....go to a animal or feed store...they sell different sizes of plastic syringes for a couple of bucks a bag.....I think there is 5 in a bag.
Great for epoxy and yellow glue (Elmer's Carpenter).....toss em' when done....no more of that SIG $5 each nonsense.
AMA 5053
