  • June 18, 2025, 07:25:04 PM
Author Topic: horizontal stab repair question  (Read 1982 times)
Offline Chris Belcher
« on: November 11, 2013, 03:54:49 PM »
I have a Forerunner that didn't make it out of the outside part of a square 8. Inverted pancake basically. Only damage is outboard stab broke off flush with fuse. Should I just shove it back together, align and epoxy (foam core) or should I dig out and rebuild? I know ...vague but that is truly the only damage other than the rudder knocked off but that's easy...oh and a bent needle valve...but that's easy too..
Offline MarcusCordeiro
Re: horizontal stab repair question
« Reply #1 on: November 11, 2013, 06:02:07 PM »
I'd repair it, using a stick of bamboo or  something to reinforce it.
And epóxi, of course.
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline 55chevr
« Reply #2 on: November 11, 2013, 06:58:14 PM »
I would build a new one ... too easy to do and no regrets later.
Joe
Joe Daly
« Reply #3 on: November 12, 2013, 03:06:33 AM »
Well,that's 2 against 1... LL~
Replacing is Always better... Ups, 3X0 now??? LL~
Marcus
Aces High!
« Reply #4 on: November 12, 2013, 11:29:04 AM »
 If the rest of the plane is all in good shape, solid and worth continuing with, I'd say put in a new stab. D>K
« Reply #5 on: November 12, 2013, 11:42:30 AM »
Ditto here,  you will thank yourself later for the new stab.
« Reply #6 on: November 12, 2013, 12:37:41 PM »
I would definitely go with the new stab, BUT, I would also cut into the bottom of the wing center section and inspect the spars.  A smack-down hard enough the pop the stab in two could also have done damage there that could later fold up on you.  I've had that happen where the damage was totally inside the wing and didn't show until the thing got floppy on me!  Fortunately, I saw it before it happened in the air.
« Reply #7 on: November 12, 2013, 02:41:25 PM »
Hmmmm, now that's good thinking. It did smite the earth.. tho in a glancing fashion. That sound!! I hate that sound. Not that I crash alot but this was a practice session to get the bottom outside squares at the correct height and ....well....I didn't. My worry now is that this plane weighed 50 oz before the crash. It was a bit doggy...not bad but right there where anymore added weight might push it over the edge...
Any ideas on lightening the tail feathers in the process? I had to hang the stock LA46 muffler to get balance.
« Reply #8 on: November 12, 2013, 02:58:56 PM »
 If you take time to do a quality repair it shouldn't affect the weight enough to matter. Sometimes you'll even surprise yourself and end up losing a slight amount. I say just go for the fix, and get it back in the air.
« Reply #9 on: November 12, 2013, 03:09:08 PM »
Make a new, built-up framework stabalizer...and elevators. If you do a quick repair of the broken stab and it breaks in the air, you could lose the rest of the model and the engine.  H^^ Steve
« Reply #10 on: November 12, 2013, 03:54:18 PM »
Any chance the built up unit would weigh less than the sheeted foam that's on there now? I know I've seen comparisons on wings before...built up vs framed up. That would be bonus as i could lose some nose weight and thus overall weight. What's funny is this forerunner weighed 41 oz 17 years ago when i built it and it was TOO light...didn't fly that well...of course especially in the wind. And the nose was weak and the engine runs...well...you know. I was so proud that I got it to come out so light but after re-working the nose (balsa tripler) nowit's a bit heavy.
Offline 55chevr
« Reply #11 on: November 12, 2013, 03:59:32 PM »
My Forerunner is electric Scorpion motor 3k batteries. Weighs in at 54 oz and flies like a dream. Rock steady and very maneuverable. Best flying plane I have ever built.  I added 1/2" to the nose based on adding weight to my last Forerunner nose to balance.  I also built up both stab and elevator on the one.
Joe
Joe Daly
Offline 55chevr
« Reply #12 on: November 12, 2013, 04:56:03 PM »
Chris - Post a photo ... I love Forerunners.
Joe
Joe Daly
« Reply #13 on: November 13, 2013, 10:35:32 AM »
I had a bucanner that weighed 52 oz and flew like that...nice crisp corners, tracked so stable...and it has pretty much the same dimensions as the forerunner..kinda close anyway.  I need to do some more trimming on the Forerunner. It turns outside well but hinges. Insides are bad. Overhead is good but outsides go light a little. maybe that's why i smote the earth on the outside square...or just bad timing on my part...probably the latter ;)
