  • June 20, 2025, 07:57:32 AM
Author Topic: Routing leading edge  (Read 3645 times)
Offline Greg McCoy
  • flying tiger B24 gunnery school patch Laredo
« on: August 15, 2010, 06:34:01 PM »
Building a Mongoose I dread shaping the leading edge with plane and sandpaper. I use routers almost daily at work, so how could I set-up and rout the leading edge?
The guide is made of 1/2 inch MDF, glued.
The cutter is 1/4 inch radius.
After the first pass, I flipped the stock and made a pass to make it symmetrical.
AMA 77370
Re: Routing leading edge
« Reply #1 on: August 15, 2010, 07:43:33 PM »
1/4 round?  So the ribs are fish-mouthed?
How do router blades hold up with balsa?  It's my experience that anything you use to cut balsa has to be sharp sharp sharp or it'll tear instead of cutting -- harder woods seem to be more forgiving for blades that you've let go too long, since they're more likely to burnish (or fry) a bit rather than ripping up chunks or skating over the wood entirely.
Offline Greg McCoy
« Reply #2 on: August 15, 2010, 08:06:06 PM »
This was a carbide cutter, it seemed to work fine. Most of the router work I do is on aluminum.
AMA 77370
Offline kenneth cook
« Reply #3 on: August 22, 2010, 07:22:01 AM »
          Greg, I was just wondering about the process you used to make these leading edges. I find it funny that the conversation I had was in fact about the leading edge of a Mongoose that one of the club members fly. He in turn is a upcoming flyer who is going to be in need of a new leading edge when his bites the dust. He's just learning inverted flight and its not going so well. Also, we fly Ringmaster's by the handful at times with multiple flyers in the circle. We mainly glue the RIngmaster's back together which over time gets pretty heavy. It would be nice to make a new solid leading edge and maybe hollow the inside out. Realizing that the majority of kit manufacturers back then used a solid leading edge and our current source is drying up. You ask yourself what to do. Is it my understanding that you are making 2 quarter round stocks and gluing them together? I myself use routers on a daily basis but not much in turn of different set ups. I use them mainly for hinge gains and Corian installations. Most bits consist of bearing guided cutters in which were just doing a one sided pass along a straight edge. I figured the first pass would be the easiest but the second one doesn't allow the bearing to have enough area to follow. I thought I could always drop the fence back giving the bearing enough room to ride on the square stock then sand the rest of the radius in. This would probably suffice for the shape,  but not very time efficient. I also thought of getting a cutter made which would be the ultimate factor but the cost is nearing $160.00. This may still be the best option. I have a thumbnail bit which looks the closest to what I need but the radius isn't quite the same as it looks more like an elipse vs a radius. I just thought it may be a matter of playing with the depth. What do you use to hold the wood on the mdf? How is the weight once completed? Does the stock take off and warp afterwards?Ken
Offline Jim Pruitt
« Reply #4 on: December 05, 2010, 05:53:18 PM »
Perhaps this is not the thread to be asking this but I have some questions about how one makes leading edge stock.
I have posted on a couple of the RC forums and never gotten an answer that I feel really answers the question so please bear with me.
Leading edge stock is getting really hard to find and often only comes in a couple of sizes.
If I try to make my own (and do not use a router) how do I make the stock?  I realize that I start with a piece of square or rectangular stock the side I need but how is the shape determined?  I gather that it is parabolic.  How critical is that or is the semi circlular shape just as good?
I originally asked the question because I needed a replacement leading edge for a CG Skylane62 kit that needed a new wing (it crashed in the hangar).
If I am hand making this piece of leading edge I assume that I draw the airfoil on each end and sand to that but again,  is that shape semi circular or is it parabolic?  If parabolic,  how is the shape actually drawn (French curve)?
I now have need of that information to fix/rebuild a CG Buster and would like to know how to make my own anyway.  This is something that I have not really seen addressed in other forums and yet it seems like basic information (that I am lacking and am sure others are lacking that information too).  I know that some kits just use a square piece  turned to a diamond shape for the leading edge.
Thank you for your patience.
Jim
Offline Leester
« Reply #5 on: December 05, 2010, 06:48:33 PM »
Not sure if this is what you mean but I trace the airfoil from the plans on card board and cut it out as a template and sand to fit using the template to check down the length of the LE.
Leester
ama 830538
Offline Jim Pruitt
« Reply #6 on: December 05, 2010, 10:16:55 PM »
That would be the technique if I had an end view to trace.  In most cases I have an assembly plan (maybe) so few parts layouts and the only info would be maybe a call out of 3/8"x5/8" leading edge stock so no shape given.
« Reply #7 on: December 07, 2010, 04:43:22 PM »
If I could scan it.  The plans for the Brodak Jr Flite Streak show how they do the leading edge.  I think it is the same on the Baby Flite Streak and the Goldberg kits that Brodak is now doing.  H^^
Offline Geoff Goodworth
« Reply #8 on: December 09, 2010, 03:04:33 AM »
Doc, you are close. Pat used a 3/8" sq LE with 3/32" sheet top and bottom, butted to the back of the 3/8 for the Cosmic Wind. I used 3/16" sq for the LE with 1/16" sheet curved down over the ribs and on the top and bottom of the 3/16" for the Shoestring.
Cheers, Geoff
« Reply #9 on: December 09, 2010, 12:00:11 PM »
The problem I've had using a router bit to shape balsa parts is that the heat generated warps the wood badly.  The same problem using a table saw.  I get good results only with the band saw with a "skip tooth" blade, which carries away the heat in sawdust.
I've built several S-1 Ringmaster models using a 3-piece leading edge, and sanding after assembled.  This doesn't warp, and is light and strong.
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #10 on: December 10, 2010, 08:18:04 AM »
Thought using a router was pretty common but guess it isn't.. A cheap router and router table are real handy to have in your shop, mine came from Sears and seem to remember having less than $75.00 invested in both the router and table. I did buy a set of quality carbide bits that were a little expensive but Harbor Freight might be a good place to start.
One of the operations it really shines is rounding over the corners of a profile fuselage. I use a half round cutter and no more grinding on plywood doublers with sand paper to round off the outside edges. It still takes a little touch up but not near as much as starting without the router.
Can't help on the leading edge, never used the router for that but what Greg did looks like it worked well..
« Reply #11 on: December 11, 2010, 09:55:04 AM »
If you are burning the wood while routing, you are feeding too fast.  I just wonder how Goldberg and Sterling made their leading edges? H^^
Offline don Burke
« Reply #12 on: December 11, 2010, 11:49:59 AM »
A method to remove a lot of material in a hurry from things like LE square stock is to use a razor plane.  Use the plane to rough to shape, then finish with sandpaper.  It doesn't overheat the wood as much as sanding and is a lot easier on the lungs, the chips can be swept up instead of inhaled.
Here's a link to one.
http://www.hobbylinc.com/htm/mas/masma4100.htm
The planes available now are not what used to be around.  The oldies but goodies used double edge razor blades,( remember those?).  These new ones work but not as well as the "real" razorblade planes.
don Burke AMA 843
Menifee, CA
Offline Allan Perret
  • Proverbs
« Reply #13 on: December 11, 2010, 03:43:10 PM »
In my experience, feeding too slow will cause burning.  Feeding too fast causes roughness in the cut.
Allan Perret
AMA 302406
Slidell, Louisiana
  • Proverbs
« Reply #14 on: December 11, 2010, 03:51:20 PM »
I have ripped balsa on table saw several times, never generated any heat because it is so soft of a wood.  If you are generating heat either your blade is dull or the blade / fence alignment is out.
Balsa can warp from internal stresses of curved grain even if you rip it with exacto blade.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Jim Pruitt
« Reply #15 on: January 20, 2013, 04:13:36 PM »
I have never been totally sure what router bit and shape to get.  This Barton forum thread was very good about answering some of that:
http://controlline.org.uk/phpBB2/viewtopic.php?p=110335#110335
Where John told me to "bit you want is a carbitool round over fillet" but I have not found a source for those in the USA.  Also what size is needed?  If the plan calls for a 3/4" x 3/4" LE then is a 3/4" round over bit needed or is it 1.5"?  Also,  John did tell me that the shape is elliptical.
As for my router and table,  it was also a cheap Sears but they were about $100 when I got mine.
Offline sleepy gomez
« Reply #16 on: January 20, 2013, 04:58:29 PM »
If you are using a table saw for balsa get a hollow ground blade.  It will give an almost sanded surface.
Offline Jim Thomerson
« Reply #17 on: January 21, 2013, 07:13:11 PM »
What I have gone to is making a couple of forms out of pieces of solid leading edge, and using them to make a molded leading edge.  I have a lot of 1/32 sheet,  I wet two pieces of the sheet with water with a spritz of simple green. I wet a piece of glass down with the water, lay the 1/32 sheet down and spray it on the top.  In maybe a minute it is like a wet noodle.  I wrap the form with plastic to keep it dry, put the two sheets in place, with some pins through to keep them centered, and wrap the whole thing with Ace bandage.  I let it dry over night.
I take the top sheet off, and spread a really thin layer of epoxy on the sheet still on the form.  Maybe I run a couple of carbon fiber strips down the length, the put the top back on and re wrap.   Once dry, I trim the back edges of the sheet to suit, then glue it on the ribs, then D-tube it.  Gives a very strong, light leading edge.
