  • July 06, 2025, 08:42:53 AM
Author Topic: Hide that ugly music wire  (Read 1788 times)
Offline Peter Nevai
    • C3EL
« on: July 16, 2011, 08:51:01 AM »
A easy light weight way of dressing up music wire landing gear is colored heat shrink tubing. Cut to length and slip on befor the final bend, or it be put on afterwards it's just a bit tougher to negotiate the bends. It comes in a multitude of colors, weighs next to nothing, holds paint real well (if the stock colors don't suit) and durable. CA glue takes to it real well (shrink it firrst). Used properly it can hide a multitude of sins.
Re: Hide that ugly music wire
« Reply #1 on: July 16, 2011, 01:38:57 PM »
My wire landing gear usually gets painted along with the rest.  Not by design, but it happens.
Online Paul Taylor
« Reply #2 on: July 16, 2011, 09:10:23 PM »
Great tip!  I will give it a try
Offline Peter Nevai
    • C3EL
« Reply #3 on: July 17, 2011, 09:20:09 PM »
Nose gear wire example
« Reply #4 on: July 18, 2011, 11:35:43 AM »
Ok, so how do you plan to hide the ugly shrink tubing? I suppose paint would stick to it ok, but I don't see any other gain. Why not just slip a piece of fuel hose over it, with a sleeve of aluminum tubing over that?   ~> Steve
Offline Peter Nevai
    • C3EL
« Reply #5 on: July 19, 2011, 12:27:47 PM »
Fuel tubing much of which is thick wall and semui transparent. Resists paint or adhesives. Bare wire painted chips easily and cracks when flexed. It all depends what you want to do. It is better than paint in protecting from rust and the like, already comes in colors, takes paint, epoxy, CA, over the bare wire very well. No one says you have to use it. Just that it is a perfectly good way of covering up the bare metal. It is better than most fuel tube because silicon in most tubing resists paints and glues. Also Heat shrink does just that it will shrink and conform to the wire shape exactly wihout adding bulk. It provides a grippy non slip surface better for attaching landing gear treatments using clips or clamps.
How many people out there have epoxied on a Wheel cover of some sort only to have it pop off every landing because the wire is just not great at holding ashesives. Heat shrink is not a miracle cure but it will help out a good deal.
  • Gravitywell
« Reply #6 on: July 19, 2011, 12:54:56 PM »
You could also cut small "V" shaped wedges and place one at the front and another at the back of the landing gear.  Then put the Heat shrink over all of it and shink.  Instant streamlined wire.  I really like this idea and I will be giving it a try for sure. H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Online Larry Renger
« Reply #7 on: September 23, 2011, 01:15:47 PM »
Hey, it works!   o2oP
I am building a Sarpoulos Corsair and wanted to add the LG covers to the struts.  I used heat shrink on the wire, then CA'ed the wood to the tubing.  WOW is that strong.
THANK YOU FOR A GREAT BUILDING HINT!!!  (PE**)
Offline Chris Wilson
« Reply #8 on: September 27, 2011, 05:24:06 PM »
I find that heat shrink tubing very beneficial when you have a wire undercarriage that has been wrapped and soldered - the tubing hides the windings very well and usually will shrink down from two wires, across the wrapping and down onto the single wire in one smooth flowing line.
MAAA AUS 73427
