Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 30, 2025, 10:55:03 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Building techniques
(Moderator:
RandySmith
Legacy Wing Set-Up
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Legacy Wing Set-Up (Read 1197 times)
Balsa Butcher
24 supporter
Trade Count:
0
Admiral
High Desert Flier
Legacy Wing Set-Up
on:
February 12, 2009, 12:23:06 PM »
I am framing up a Legacy wing. The (excellent) Brodak instruction book is MIA. (I think I know where it is but it is not accessable at present). I just need one number: What size shim does is specified to put under the 1/4" spar at the wing tip (#14 rib). My guess is a 3/16 or 1/4 shim at the tip but...I needs to know. Thanks in advance. Pete
Last Edit: February 12, 2009, 05:53:37 PM by Pete Cunha
Logged
Pete Cunha
Sacramento CA.
AMA 57499
John Miller
25 supporter
Trade Count:
0
Admiral
Re: Legacy Wing Set-Up
Reply #1 on:
February 12, 2009, 01:43:44 PM »
Pete, I just checked the CAD file, and the distance from the wing chord centerline is .197 less at the tip, so 3/16" is about right.
Last Edit: February 12, 2009, 03:39:23 PM by John Miller
Logged
Balsa Butcher
24 supporter
Trade Count:
0
Admiral
High Desert Flier
Reply #2 on:
February 12, 2009, 02:04:27 PM »
Thanks John, by my measurements that's what I came up with as well, just wanted to make sure. Hopefully see you in Tucson next month. PC
Logged
Pete Cunha
Sacramento CA.
AMA 57499
John Miller
25 supporter
Trade Count:
0
Admiral
Reply #3 on:
February 12, 2009, 03:40:15 PM »
I'm looking forward to it. Good luck on the Legacy.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Building techniques
(Moderator:
RandySmith
Legacy Wing Set-Up
