I've only had a couple opportunites so far to try out the new Helldiver. I knew it was a little bit tailheavy and corrected that to within reason with some bench trimming prior to the initial flight a few weeks ago. I've only got four flights on it to date, and it's
really quick on the controls and still a little tailheavy. There is no access built in to the model for control adjustments. After the first flying session of two flights I did up a new handle with 2-3/4" line spacing and the controls are still plenty hot, but much, much better. A few more trimming flights to get the balance right, and we'll be good to go. It flies like a bandit and goes anywhere you point it, a lot like a
combat plane actually.
Last Monday evening I went out and put up flights three and four, and during number four I was viciously attacked by an angry swarm of the Minnesota State Bird. Combined with that distraction and the still somewhat hot controls, and the "iffy" balance, I bonked the landing and the gear doors smacked through the leading edge sheeting. At least it stayed on the wheels though. Damage was fairly minor, but enough to warrant a proper repair and a modification to the gear doors for a bit more clearance.
For the fix, I was able to just bend a T-pin into a hook, reach in and pull the sheeting back into place, and then soak the area with CA and let it set up. Then, I filled and sanded the area with some red body putty and then stuck a small piece of carbon fiber over that. I've got it all sanded smooth now so with a touch-up shot of white and some clear we'll be ready for battle once again!
