  • June 19, 2025, 11:15:47 PM
Author Topic: Has anybody used the Brodak wing jig?  (Read 1545 times)
Offline Geoff Goodworth
« on: June 13, 2013, 09:28:04 PM »
The Brodak wing jig is a fairly clever gadget using two 5/16" dia tubes 36" long.
This limits wing panels to about 33" or 34",
If you assemble wings in two panels on this jig, how do you join the panels and where/how do you locate your bellcrank?
Offline Balsa Butcher
  • High Desert Flier
Re: Has anybody used the Brodak wing jig?
« Reply #1 on: June 13, 2013, 11:41:33 PM »
I have used it on a Legacy 40 wing. Found it very user friendly. After building the two wings to include leading edge  sheeting, put them back on the jig with the middle of the tubes centered in the center of the wing. This keeps the two halves in alignment. The outer 6" or so will be outside of the jig, unsupported. That's OK. Glue the two halves together and slip the tubes out. You now have a complete one piece wing. Mount the bellcrank in any of the usual ways. I made top and bottom mounts and mounted it in the so-called floating style. As far as the two piece wing, most free-flight and many R/C designed are constructed this way so it is not unusual. 8)
Join them the same way you would if you were making a one piece wing that was joined in the middle. Once both wings are threaded onto the rods, that is essentially what you have. 8)
« Last Edit: June 14, 2013, 09:55:06 PM by Balsa Butcher »
Pete Cunha
Sacramento CA.
AMA 57499
Offline James Strickland
« Reply #2 on: June 14, 2013, 01:27:36 AM »
We always did it that way when we All built flat on the bench, before anyone offered any fancy-schmancy tools (jigs)  just look at any of the old built-up Sig kitsie Chipmunk, Akro-Master, Twister, Banshee etc.  No biggie.
« Reply #3 on: June 15, 2013, 06:56:00 PM »
Thanks for the comments. I must add that I'm concerned about strength in the trailing edge with two completely separate wing panels.
While I don't have a set of ribs to suit at present, having played around with mine, I think I will use 3/4" fold back clips to hold things together rather than the supplied clothes pegs. The clips are stronger and you can fold the arms out of the way. Much less vulnerable during the early stages of setup.
  • High Desert Flier
« Reply #4 on: June 15, 2013, 09:24:32 PM »
Most wings are two completely separate panels...they are just built at the same time and joined in the middle. Only difference with this jig is they are built separately then joined in the middle. A key is the accurate holes in the rib for the rods to go through. Thae kit ribs are lazar cut for this. If built from scratch it is more more work and must be done precisely or wing alignment will suffer. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #5 on: June 16, 2013, 10:52:02 AM »
All my wings are built in two panels, on 1/4" rods.  Joining, you just match the spars, L.E. and T.E.  Butt joints are not strong, so plywood plates are put on spars, L.E. and T.E.
If the wing has dihedral, block up one panel, sand the spars to meet, and proceed as before.
