  • June 20, 2025, 04:36:14 AM
Author Topic: I'm a searchin'  (Read 1277 times)
Offline Bootlegger
I'm a searchin'
« on: May 04, 2012, 08:22:53 AM »
  Lookin' for a root templet of the full size flight streak rib's..
  Who can help?
  Thanks a lot,    y1
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: I'm a searchin'
« Reply #1 on: May 04, 2012, 09:26:29 AM »
Try this... Hopefully the size is still correct after converting to jpg and uploading, if not you'll probably have to adjust the size.
Offline Gene O'Keefe
Re: I'm a searchin'
« Reply #2 on: May 05, 2012, 06:01:50 AM »
I've got an unmolested Flite Streak kit stashed away....if no one else has an immediate copy, I'll dig it out and copy it for you.
Gene O'Keefe
AMA 28386
Offline Bootlegger
Re: I'm a searchin'
« Reply #3 on: May 05, 2012, 04:23:29 PM »
  Guy's I should have said that I was looking to make some templets to cut a flight streak wing from foam.
The way those ribs in the kit were cut I couldn't use the stock ribs.
  I apologize for any confusion, and thank all y'all for the responses.
  Again, I apologize...
Gil Causey
AMA# 6964
Offline bill bischoff
Re: I'm a searchin'
« Reply #4 on: May 06, 2012, 10:18:59 AM »
I sent you one by email.
Offline Joseph Patterson
  • AMA member- Supporter
Re: I'm a searchin'
« Reply #5 on: May 09, 2012, 09:51:48 PM »
       Gil,
           You can use the stock rib to make a template. TRACE the rib and use a french curve or a compass to make a full leading edge. I'm assuming you were referring to the leading edge when stating you could not use the stock root rib due to the way it is cut-out.
       Doug
Offline Bootlegger
Re: I'm a searchin'
« Reply #6 on: May 15, 2012, 04:12:10 PM »
   <=  Guy's I sure do appreciate all the help with the rib templets.
  Sparky again thanks for the best web site for Stunt... #^
Gil Causey
AMA# 6964
