  • May 21, 2025, 12:04:43 AM
Author Topic: Gorilla glue  (Read 2582 times)
Offline Bootlegger
Gorilla glue
« on: August 16, 2018, 11:48:28 AM »
  Guy's  I have not used this glue, so I am looking for  ways to successfully use it, and which one have you found works best? Thanks a lot
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Fredvon4
  • Central Texas
Re: Gorilla glue
« Reply #1 on: August 16, 2018, 01:10:48 PM »
Gill brother...here are about 30 formulations of glues Branded as Gorilla glue
Some are excellent for some applications and some are pure disaster for some applications
Any Way..
Gorilla is a brand not a specific TYPE of any glue
Gorilla has :
Cyanoacryliates  (CA)
Poly U glues....foaming and non foaming
Wood aliphatic types...sort of like Elmers or Tite Bond
Rubberized concotions
J&B weld type concoctions
and a lot others I do not directly recall as I write this
The best advice I get here on the web forums is to try to describe the task I want to do and ask what is best method and products
Not trying to be a butt head but you just asked way too broad a question
Gorilla glue for Balsa skinning a foam wing core is vastly different for the best Gorilla glue to form up a rib n spar wing
IN my person bin of adhesives I have well over 15 different brands and types for various tasks....and grin -----it would sure be easier if there was ONE perfect go to glue to crate a good solid stiff model
Fred von Gortler IV
Offline Bootlegger
Re: Gorilla glue
« Reply #2 on: September 05, 2018, 07:33:26 AM »
   Fred, I have to apologize about being so late to say "Thanks" please don't hold it against me but now I want to say Thanks a lot...
Gil Causey
AMA# 6964
Re: Gorilla glue
« Reply #3 on: September 05, 2018, 01:14:03 PM »
The green foaming stuff is great for foam wings.  It used to be THE Gorilla Glue, until they branched out.
I have some clear foaming stuff that also works great on foam wings, but I don't know if that's their current clear formulation.  Someone needs to try it and report back.
Online Brent Williams
Re: Gorilla glue
« Reply #4 on: September 05, 2018, 03:46:29 PM »
I have used the white Gorilla glue on a lot of foam wing repairs.  It comes out of the bottle clear and foams up white as it hardens.  Works miracles in repairing foam wings quickly.  I put my wing back together at least 15-20 times as I learned the pattern.  https://www.gorillatough.com/product/white-gorilla-glue/
There is a new "clear" Gorilla glue that apparently does not foam and dries clear.  I must try it.  https://www.gorillatough.com/product/clear-gorilla-glue/
Re: Gorilla glue
« Reply #5 on: September 05, 2018, 04:37:37 PM »
I have used the white Gorilla glue ...
There is a new "clear" Gorilla glue ...
Hey Brent -- thanks for pointing that all out.  I saw the clear come out and thought "oh holy ****, they've gone and taken away my favorite!"  I suspect that we'll still want to use the white foaming stuff on foam -- I'm curious now what chemistry the clear stuff is (I doubt it's urethane).
Re: Gorilla glue
« Reply #6 on: September 05, 2018, 06:04:01 PM »
Here's the SDS for the clear Gorilla glue.  Those of the chemical interpretation persuasion can divine ingredients better than I.
https://www.gorillatough.com/wp-content/uploads/Clear-Gorilla-Glue.pdf
Re: Gorilla glue
« Reply #7 on: September 05, 2018, 07:18:33 PM »
Well, I can't tell you exactly what it is, but from the list of solvents it should be great if you're inclined to get high by sniffing glue.  I should get some and try it out (to stick things together, not to get high).  In a well-ventilated area, and without drinking any.
Re: Gorilla glue
« Reply #8 on: September 19, 2018, 07:01:24 PM »
According to the data sheet, it's a silicone glue(sylyl, siloxane) the first two ingredients.  The rest are solvents.  The piperidin stuff usually has a nasty smell, but it isn't very volatile.  You certainly wouldn't want to drink it!
Use gloves and eye protection.
