  • June 16, 2025, 10:48:56 AM
Author Topic: Weight boxes. Mounting?  (Read 1769 times)
« on: July 11, 2014, 02:47:19 PM »
Those that are using weight boxes, are you mounting them on the CG? Or at least as close to the CG as possible?
Thanks in advance.
Charles
Re: Weight boxes. Mounting?
« Reply #1 on: July 11, 2014, 02:56:20 PM »
I don't think they need to be dead on, but close is nice.  Mine usually end up in line with, or just in front of, the wing spar.
Offline Jim Thomerson
« Reply #2 on: July 11, 2014, 03:11:25 PM »
And try to have them more visible from the bottom than from the top.  I have installed a couple with the wing upside down.  You just have to pretend you meant to do so, and incorporate them into the color scheme.
« Reply #3 on: July 11, 2014, 06:34:14 PM »
Tim & Jim,
Thanks for the reply.
Should have said it was a Ringmaster wing, "Look Ma no spar!" Or at least none on the CG.
I placed the box as far forward as the thickness of the rib would allow. Cheated a bit because I added 3/32 strips on the top and bottom of the wing. Not so much to increase the airfoil thickness, but to clean up the ribs. Does add a little thickness.
Bar sanded a tad off this stock anyway.
Close to covering.
Couple coats of dope, some CF even over the ribs, I'm kidding!
Just the dope then covering.
I may use the Dave Brown Skyloft I have. Ancient it is but it is nylon and designed for open bays.
I have no silkspan and the local HS wants 5.00 a sheet. Someone said they were getting their silkspan out of a HS in Texas for 1.00. This was 00 silkspan.
I might start a thread and ask about that.
I also can't believe I'm painting open bays without using a flexing agent in the paint. Primer included.
