  • July 17, 2025, 10:23:48 PM
Author Topic: Gluing Plastic Pilot  (Read 1064 times)
Online Motorman
« on: February 26, 2020, 06:49:54 PM »
blank
« Last Edit: August 24, 2021, 09:07:16 PM by Motorman »
Re: Gluing Plastic Pilot
« Reply #1 on: February 26, 2020, 07:21:56 PM »
MM,
The ones I've installed I used Sig-ment to glue it to the floor and used a small screw up from the bottom. I think the Sig-ment would hold the two half's together.
Best,   DennisT
« Reply #2 on: February 27, 2020, 12:17:23 AM »
If ya gotta, just gotta improvise on the glue you might try xylene. I think it is the main ingredient in actual, for real, plastic model cement. I'd sure test it on some scraps first.
I made a few pilots a few years back. I thought I would screw at least the first one up because I'm not really a plastics kind of guy. They turned out fine, and I had fun making them.
I drilled a pair of holes in the base, and glued and pinned the bust to the balsa "floor." I'd try a flexible glue myself. Canopy glue might be the ticket.
Good luck with yours,
Offline L0U CRANE
« Reply #3 on: February 27, 2020, 10:44:44 AM »
Also, whatever you use to join the front and back together, look at the joint seam. If it is very noticeable, scrape it down gently with a #11 blade, held vertical to the surface.
Sand the base flat. It may have joined at an angle which prevents full contact with the surface under it. Sanding with a fairly coarse grit (100 or 60, e.g.) also provides more "tooth" for the bond. SIG-ment works; so does the RC56-type canopy glue, and epoxy, and aliphatic, etc., etc...
If you have a prominent moustache, beard or sideburns, paint them on, too...
\BEST\LOU
« Reply #4 on: February 27, 2020, 03:15:04 PM »
Once the pilot is glued in, under a plastic canopy, it is then captured forever!  To prevent the plastic pilot from rattling around after it has broken loose, I usually drill a hole in the bottom of the pilot figure, and in the cockpit floor.  I pin them together using a balsa "dowel" made from a piece of hard 1/4" square balsa.  Don't depend on just glue.  Use a dowel, plus glue (epoxy for the doubters).
