Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
June 19, 2025, 01:23:30 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Building techniques
(Moderator:
RandySmith
Bellcrank and leadouts
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Bellcrank and leadouts (Read 4183 times)
Richard Logston
Trade Count:
0
Commander
on:
April 17, 2014, 10:34:26 AM »
I am finishing up a 38 Special profile version to be powered by a .40 OS max engine. Question, I have a 4 inch black plastic bellcrank ( actually looks like carbon). What would be the best way to attach the lead outs? Should I use a small tube for the wire to bear on or can I just thread the wire through the original size hole without it cutting into the bellcrank in service. I have been out of C/L since the middle sixties, but have built several c/l airplanes in the last three years. But have only flown two flights since getting back.
Logged
Bill Little
2017
Trade Count:
0
Admiral
Second in COMMAND
Re: Bellcrank and leadouts
Reply #1 on:
April 17, 2014, 10:43:21 AM »
Hi Richard,
The tubing route is a great way of doing the lead outs, connecting them to the BC. That is the way I do all of mine bigger than 1/2A.
BIG Bear
RNMM/AMM
Logged
Big Bear
AMA 95351 (got one of my old numbers back!
Tim Wescott
25 supporter
Trade Count:
0
Admiral
Reply #2 on:
April 17, 2014, 11:27:15 AM »
Tubing. Even if you have to open up the holes a bit.
I use 3/32" OD tubing from the hobby shop. There are folks who have found smaller tubing, which would work better, but I don't know where to get it (McMaster-Carr?).
Here's how I did it on my last plane. Everything worked well, except the part about forgetting to thread the control system through the wing first, and thus having to unwrap the ends, thread on the leadout guide, and rewrap.
http://stunthanger.com/smf/index.php?topic=27915.msg273968#msg273968
Logged
Richard Logston
Trade Count:
0
Commander
Reply #3 on:
April 17, 2014, 03:02:03 PM »
Thanks for your replies. Much help.
Logged
55chevr
2016 supporter
Trade Count:
0
Captain
Reply #4 on:
April 17, 2014, 04:54:02 PM »
Yup, McMaster Carr
Logged
Joe Daly
Allan Perret
2017
Trade Count:
0
Admiral
Proverbs
Reply #5 on:
April 17, 2014, 06:08:12 PM »
K&S has 1/16" tubing in brass, copper, or aluminum. I use the copper, the ID is just big enough to use .027" lead outs. Don't know if you can get .032" lead outs thru it, but the .027" still has breaking strength of 125#.
Logged
Allan Perret
AMA 302406
Slidell, Louisiana
Don Hutchinson AMA5402
2014 Supporters
Trade Count:
0
Captain
Reply #6 on:
April 17, 2014, 07:39:07 PM »
I also use the K&S 1/16 brass tubing and 135# test cable. It mikes at about .030. I get it at a good fishing store in a small spool, normally used for salt water leader material. Just for fun, anybody know who K and S are??
Logged
Dick Pacini
25 supporter
Trade Count:
0
Admiral
Reply #7 on:
April 17, 2014, 09:17:00 PM »
http://www.ksmetals.com/
Logged
AMA 62221
Once, twice, three times a lady. Four times and she does it for a living. "You want me on that wall. You need me on that wall."
FLOYD CARTER
24 supporter
Trade Count:
0
Admiral
Reply #8 on:
April 19, 2014, 09:50:31 AM »
Most likely named for the owners... like Ken and Sam (maybe?)
Logged
AMA #796 SAM #188 LSF #020
2014 Supporters
Trade Count:
0
Captain
Reply #9 on:
April 19, 2014, 07:15:56 PM »
Not even close, try again.
Logged
2014 Supporters
Trade Count:
0
Captain
Reply #10 on:
April 21, 2014, 11:50:26 AM »
A couple of guys from the Chicago area who were well known free flight modelers late 30's and 40's era. Wally Simmers of Gollywock and Jabberwock fame and Joe Konefes of Buzzard Bombshell fame. Ya gotta be an old old timer to know trivia like this!
Last Edit: April 29, 2014, 10:22:52 AM by Don Hutchinson AMA5402
Logged
Dennis Toth
2020 supporter
Trade Count:
0
Admiral
Reply #11 on:
May 20, 2014, 04:38:17 PM »
Rich,
With the 38 Special as the leadouts are coming through the fuse be careful to bring the ends of the tubing into a tear drop shape and make the fuse holes large enough to have a little wiggle room around where the leadouts come through.
Best, DennisT
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Building techniques
(Moderator:
RandySmith
