  • June 18, 2025, 11:57:34 PM
Author Topic: Another Magnum in Progress 2  (Read 2781 times)
Offline Greg L Bahrman
« on: June 13, 2006, 08:32:45 PM »
Progress is slow but we got the bottom sheeted and the fuse covered in veil. The veil made a big difference in the stiffness of the sheeting. I have been considering painting the fuse and monocoating the wings to save weight. Your thoughts         n~
 y1
« Last Edit: July 20, 2006, 08:39:09 PM by Greg L Bahrman »
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline RC Storick
Re: Another Magnum in Progress 2
« Reply #1 on: June 13, 2006, 08:51:15 PM »
 :! Paint it all! You  will be much happier!  j1
« Reply #2 on: June 13, 2006, 09:07:31 PM »
Robert,
If I paint it all, should I silkspan the wings or continue with the veil?? Also will the dope (sig) penetrate the 1/16 balsa and damage the foam ??
Simi Valley, Ca.
Offline RC Storick
« Reply #3 on: June 13, 2006, 10:39:54 PM »
Brush 2 coats un-thinned clear on the wings. Apply 00 silkspan and 2 more coats unthinned clear sand and switch to 50/50 clear. CF only goes on the fuse.
Offline Mike Clark
  • Lets get together and burn some fuel!
  • ACE
« Reply #4 on: June 14, 2006, 11:25:57 AM »
Greg,
What did you use to glue the sheeting onto the foam cores? Epoxy Hopefully!
If you have done a good job at fitting your wing skins as it looks you have, matched up LE & TE, then filled your wing sheeting in places where needed, there shouldn't be a problem with the dope over the sheeted foam wing.
3 coats of 50/50 clear Dope and put down the carbon. If you have any reservations about the clear and a reaction on the foam core, then dust on the first coat.
All my previous Magnums have had silkspan & dope finishes without any problems.
$kote should be a last resort, I would think!
Mike Clark
Mike Clark
« Reply #5 on: June 14, 2006, 08:39:23 PM »
Thanks Robert and Mike,
I guess I'm committed now. I got one coat clear on the wings and will do another tomorrow.
« Last Edit: June 14, 2006, 10:12:54 PM by Greg L Bahrman »
Simi Valley, Ca.
Offline Mike Clark
  • ACE
« Reply #6 on: June 14, 2006, 09:06:43 PM »
Hey Greg,
You get an offical "ATABOY" leave the $kote in the cabinet!
I got  my Tom Morris hardware installed agjusted the flap to elevator connections and checked the flap throw, were cooking now. All nuts lock tite protected and we will close her up tommorow.
Mike Clark
Mike Clark
Re: Magnum added pic
« Reply #7 on: June 17, 2006, 10:30:40 PM »
Thanks Mike,
I bumped you up a karma for your good words. I got the wings covered with silkspan and sanded ready for primer. Still have to do fillets and other things but we are moving along. Just stuck together for show and tell.  Increased rudder area a little larger than stock. Anxious to see your progress also.  ~>
« Last Edit: July 20, 2006, 08:40:42 PM by Greg L Bahrman »
Simi Valley, Ca.
Offline RC Storick
« Reply #8 on: June 20, 2006, 07:39:43 AM »
Looks good but it doesn't look like a Magnum anymore.  y1
« Reply #9 on: July 09, 2006, 03:06:46 PM »
 Looks like a VERY nice job Greg. I really like the slight re-design! I'm also glad you took Sparky's advice, you'll be real happy that you painted it all in the end. Monokote is like chrome on motorcycles, just say NO. **)
