I dithered over putting this in "finishing" or here, but ultimately decided that it's more a structural question than a finishing one.
I was recently gifted a plane (thanks Randy) with a 12 year old silkspan and dope finish, and a honkin' big warp (this may be why you needed the trim tab) in one wing.
Based on some dimly remembered wisdom that I read a long time ago, I tried tweaking the wing and running over the silkspan with a hot air gun, just like you would with 'coat. It works great -- the warp is so far gone, it's warped in the other direction (oops).
My question is: how is this going to work in the long run? Does heat-shrinking silkspan (probably the dope, in reality) work? Am I going to be doing this all the time? Am I going to end up over-tightening the covering and splitting the silkspan?
