Well building is progressing nicely on my Raptor 2011 Edition which i'l have at this years Nats. I have been busy building away trying to get her in paint by Middle of April - As well as trying to finish off my classic ship.
I was buidling this at the same time as I was finishing:
The ares
The 2010 Raptor
My 2011 Classic model - the shop was certainly Crowded !!!!!!
Still is ... with another model in the pipe line getting close to finish.
The design of the model is my own set of numbers but Im using alot of Idea's from other successful model designs The wing on this specific model is a planiform I have not tried - I used Paul Walkers Miss america mustang wing design but with the flaps identical in size and dimension to the Dave's T.G. The only real changes made were making the wing area 630 sq and not having the Kick out at the front of the wing like the mustang. But the 1/4 Chord Root / tip is identical.
Tailplane design is similar to what I had built for my last Raptor however I again consulted with Dave on the TG design and took many of the design ques. I wouldnt say Copied because I dont have a copy of te TG plans.. I did get some accurate measurements from the man himself. One of the design features I like to have on all my designs is a very slight swept back hinge Line in the Elevator ( 1/4"ish..). You can see it on one of the photos if you look hard. Its one of those design features that I have run now for the last few ships - I like how it feels. Although I dont have any aeronautical reasons or maths to back up my findings - I did take some elements of that design from looking at larger planes like the airliners where the sweep is far more sever. I put it down to efficient design and aerodynamics. airflow would roll off the elevator so sweeping it back slightly maintains airflow for a brief amount longer. I have built several models that were VERY close to design almost identical but with this difference in stab design, and I found it more accurate, more responsive. - The same sort of effect I encountered with the Gieseke Bear tabs on the Stab - I choose not to run those- however have experimented with them on and off similar models and that was the best way I can describe the sensation - more positive and accurate through the turn.
As mentioned before I dont have any plot data however I have seen 3D wind tunnel plotting of a similar design tail and you can clearly see where the air flows, and where it doesnt . Again I'm just a Flyer and Graphic designer with no engineering background at all - so my reasons may be completely off the mark but I like how it looks and it may or may not make any " real world " difference, Call it artistic License.
Carbon Torque tubes for the flabs and Elevators - Triple carbon layer of Flaps - 5/8 Assymetry. Dual Flap tabs Rush boost tabs. I found I didnt like the feeling of full span flaps I never have - there are various threads about the merits of Full Span. I know the reasons why but Its comes down to feel in the end.
Target weight will be between 60 - 62 oz - The last Raptor pictured bottom and featured here a few weeks ago finished in at 62.5 oz ready to fly. I try to document where the weight goes at every main stage and they are along the same weight paths. I doubt it will be Sub 60..
Ball link controls used all throughout. Upon Brett's recommendation Im using the Titanuim threaded inserts inside the carbon pushrob.and Rocket #87 for the first time on this ship. All Control systems by Kaz minato. Engine is Stalker with custom head modifications done in Ukraine. Carbon tank. New Carbon/Kevlar undercarts + carbon wheel pants.
Thats about all until paint.
I only have 1 set of plans for this edition which were drawn by myself, I could get copies made if there were any credible requests.
