Building Tips and technical articles. => Building techniques => Topic started by: Chris Belcher on August 05, 2013, 10:35:13 AM
Anybody know where the CG should be for the original size Forerunner (46)...got one ready to go up. Total weight (unless CG needs adj) is 43 oz...should be a good flyer.
I will check kit plans when I get home from the damn job.
Joe
I know that feelin'
The Custom Model Plans show the CG at 2-1/2 from the leading edge at the fuselage ... Hope that helps ...
Joe
It is a custom models kit so that is exactly what I needed...THANKS!
My newest Forerunner is in construction .... Post some photos of yours - would love to see it.
Joe
Do show
Sent from my SCH-I605 using Tapatalk 2
will do...I haven't permanetly mounted the tank yet...can't decide what to do...plastic clunk or metal. The motor is LA46 with small FP40 venturi and needle valve. Have run 1/2 galon of fuel through it. Sounds ready to go.
Any suggestions on tank?
The Custom Models kit uses a plastic clunk. Fits perfectly in the fuselage cut out.
Joe
