  • June 19, 2025, 05:19:56 AM
Author Topic: Forerunner CG  (Read 1368 times)
Offline Chris Belcher
Forerunner CG
« on: August 05, 2013, 10:35:13 AM »
Anybody know where the CG should be for the original size Forerunner (46)...got one ready to go up. Total weight (unless CG needs adj) is 43 oz...should be a good flyer.
Offline 55chevr
Re: Forerunner CG
« Reply #1 on: August 05, 2013, 01:30:43 PM »
I will check kit plans when I get home from the damn job.
Joe
Joe Daly
Re: Forerunner CG
« Reply #2 on: August 05, 2013, 01:52:37 PM »
I know that feelin'
Offline 55chevr
Re: Forerunner CG
« Reply #3 on: August 05, 2013, 04:07:05 PM »
The Custom Model Plans show the CG at 2-1/2 from the leading edge at the fuselage ... Hope that helps ...
Joe
Joe Daly
Re: Forerunner CG
« Reply #4 on: August 06, 2013, 10:56:14 AM »
It is a custom models kit so that is exactly what I needed...THANKS!
Offline 55chevr
Re: Forerunner CG
« Reply #5 on: August 06, 2013, 11:02:33 AM »
My newest Forerunner is in construction .... Post some photos of yours - would love to see it.
Joe
Joe Daly
Offline Doug Knoyle
Re: Re: Forerunner CG
« Reply #6 on: August 06, 2013, 11:24:21 AM »
Do show
Sent from my SCH-I605 using Tapatalk 2
AMA 60591
Re: Forerunner CG
« Reply #7 on: August 07, 2013, 09:31:34 AM »
will do...I haven't permanetly mounted the tank yet...can't decide what to do...plastic clunk or metal. The motor is LA46 with small FP40 venturi and needle valve. Have run 1/2 galon of fuel through it. Sounds ready to go.
Any suggestions on tank?
Offline 55chevr
Re: Forerunner CG
« Reply #8 on: August 08, 2013, 04:42:29 AM »
The Custom Models kit uses a plastic clunk.  Fits perfectly in the fuselage cut out.
Joe
Joe Daly
