  • June 21, 2025, 05:21:59 PM
Author Topic: Foam wing weight  (Read 1391 times)
Dwayne
Foam wing weight
« on: November 24, 2018, 09:15:50 AM »
Just finishing up a foam wing that has 650 sq in, uncovered it weighs about 14.8 oz. Please is this good?
Thanks  y1
Offline Jim Svitko
Re: Foam wing weight
« Reply #1 on: November 24, 2018, 09:44:05 AM »
You say you are finishing up this wing but a bit more info would help.  What exactly do you mean by uncovered?  Bellcrank, leadouts, leadout guide installed?
Dwayne
« Reply #2 on: November 24, 2018, 10:03:17 AM »
Sorry it's all together, sheeted everything installed, just not finished, IE no dope or iron on.
« Reply #3 on: November 24, 2018, 10:13:18 AM »
FWIW, my built-up Brodak Legacy, 690-ish square inches, flaps & control system installed but otherwise waiting for covering is 16 ounces even.  Given that foam wings are supposed to be a bit heavier than built-up (but ignoring the fact that I tend to build heavy), you don't seem to be too far off the mark.
Offline Jim Svitko
« Reply #4 on: November 24, 2018, 10:13:43 AM »
OK, assuming your weight of 14.8 ounces does not include the flaps, hinges, horn, or tip weight, I would say the weight at this time is OK.
If the 14.8 ounces includes all the items previously mentioned, then that is much better than what I have been able to do.
