  • June 17, 2025, 12:49:29 PM
Author Topic: Lead outs for SIG Akromaster  (Read 1416 times)
Offline andreas johansson
  • SWE-56998
« on: November 19, 2012, 12:44:40 AM »
Hi guys!
Wire or solids? and how thich do they need to be? Would, for example, 0.018" wire work?
Andreas
Nobler-O-Maniac
SWE 56998
Re: Lead outs for SIG Akromaster
« Reply #1 on: November 19, 2012, 10:19:29 AM »
 .018 is plenty heavy enough for an Akromaster and will work fine. Personally, I'd stay away from the solids.
  • SWE-56998
« Reply #2 on: November 19, 2012, 10:29:13 AM »
Thanks for your replies guys! I found a roll of 0.021 cl cable/wire (do one say wire or cable?) so it will be flexible leadouts.
Andreas
Nobler-O-Maniac
SWE 56998
Offline Mike Haverly
« Reply #3 on: November 19, 2012, 12:38:05 PM »
The politically correct term is "wire rope".
« Reply #4 on: November 22, 2012, 07:17:57 PM »
I just built one with scrap .018" flying line for leadouts.  I'll be flying on .012" so anything over .018" is overkill.  I've always used .018" leadouts for even the most powerful org 15-size engines.  The weight difference isn't all that much, bit it's on the wrong side of a small plane.  Double trouble.
