Building Tips and technical articles. => Building techniques => Topic started by: Motorman on August 27, 2019, 06:46:10 PM
Title: Foam Vs Frame Weight
Post by: Motorman on August 27, 2019, 06:46:10 PM
blank
Title: Re: Foam Vs Frame Weight
Post by: Mike Alimov on August 28, 2019, 05:33:41 PM
Not sure you will ever get a definite answer to this - it depends on who/how the two wings are built, types of glues used, balsa density, method of built up construction, covering/ finish method, etc etc. For example, my SV-11 arf wings were about 15 oz (no flaps, covered with Brodak-cote). I have a set of sheeted SV-11 wings ( builder unknown) that are about 10 oz - who knows how much they will weigh when finished? At the same time, if you order built up sv-11 wings from Tom Morris, they will be feather light.
Post by: Dennis Adamisin on August 29, 2019, 09:19:13 AM
If comparing fully sheeted wings, the answer is closer to 2 ounces, not 4.  BTW, a fully sheeted built up is just as resistant to warps as a foamie.
If comparing a fully sheeted foamie to a open bay built up D-tube, and finishing with dope, I would expect the FINISHED weight of the foamie to be the same or lighter than built up.
Post by: Tim Wescott on August 29, 2019, 10:44:24 AM
Are you saying that the actual weight of just the finish for dope over sheeting is less than the finish for dope over open bay?
Post by: Brett Buck on August 29, 2019, 02:04:22 PM
   Agreed, and we have abundant evidence showing what happens when a particular builder build a specific design with foam and then D-tube. They end up weighing the same, since any weight difference in the structure it compensated for in the finishing. Saving any significant weight with a D-tube requires some special circumstance, like you removed structure to the point that the D-tube is substantially less stiff.
   This tends to get swapped around when you need to make the wing removable, and thus incorporate hard points. In that case, a build-up wing makes a lot more sense, because the structure lends itself to putting hard points as spars, etc, that don't really correspond to anything in a foam wing. You can do it, but there's a lot of dead weight.
Post by: Paul Smith on August 30, 2019, 06:24:29 AM
Well, a fully-sheeted wing is easier to sand than open bay.  So you have a better chance to sand off some excess material without risking a disaster.
Post by: phil c on October 18, 2019, 08:28:29 PM
I built several 700+ wings for the Giles series I played around with.
The wing panels complete weighed a total of about 12-13 ounces.
Finish with film added 1.5 ounces.  Silkspan and Rustoleum added another 6-7 ounces.
18-19 oz. for 700 squares.  Maybe 15-16 ounces for a 600 sq. in. wing. ready to fly.
Phil C
