  • June 19, 2025, 05:06:32 AM
Author Topic: Foam vs. Built-Up Wing Weights  (Read 4528 times)
Offline Kim Mortimore
« on: February 05, 2013, 10:42:05 PM »
On average, how much heavier is a competition-quality foam wing than a competition-quality built-up wing of the same size, percentagewise?
Thanks.
Kim Mortimore
Santa Clara, CA
Online RC Storick
Re: Foam vs. Built-Up Wing Weights
« Reply #1 on: February 06, 2013, 06:54:31 AM »
Thanks.
650 to 700 SQ is approx 1 oz difference. Almost not worth it. I do like foam wings for the durability and ease of finish.
« Reply #2 on: February 06, 2013, 10:06:57 PM »
Thanks Sparky.  And then there's the nice little bonus of making warps a thing of the past.  #^
Kim Mortimore
Santa Clara, CA
« Reply #3 on: February 07, 2013, 04:30:22 AM »
I think it is a little more than 1 oz. What is the lightest foam wing you have ever built. Fully sheeted, wing tips, leadout slider, tip weight box, bellcrank, horn, flaps, and trim tab?
I have a built up wing in my shop for a Dreadnought I will tell you what it weighs after I hear a couple foam wing weights. Bob Hunt should chime in here, he probably has built some really light ones.
Derek
Offline Rafael Gonzalez
« Reply #4 on: February 07, 2013, 05:32:50 AM »
Phil Cartier has a True Beam foam wing that I am dying to try. I am working on a fuse design to use the wing, it has all the spars at the right places.  #^ I do not know if anyone has given it a run, but it sure looks awesome! y1
 H^^
Online RC Storick
« Reply #5 on: February 07, 2013, 06:10:16 AM »
Derek
Bob and I have discussed this and I thought we came to agreement its about 1 OZ. Please chime in Bob.
« Reply #6 on: February 07, 2013, 06:19:17 AM »
All I know is....air is lighter than balsa and foam.
Derek
BUT, the foam wing makes finishing so much easier!!!!
« Reply #7 on: February 07, 2013, 06:21:07 AM »
I don't think it is much more than 1 oz. maybe 2 to 2.5 oz. Just seems like my foam wing planes always come out heavier.
Derek
« Reply #8 on: February 07, 2013, 06:38:35 AM »
I think it is a little more than 1 oz. What is the lightest foam wing you have ever built. Fully sheeted, wing tips, leadout slider, tip weight box, bellcrank, horn, flaps, and trim tab?.....
Derek
Derek,
Why would a warp-proof foam wing need a trim tab unless the foam cutting was inaccurate?  Or are you talking about a tab to increase the area of the outboard flap?
Kim Mortimore
Santa Clara, CA
« Reply #9 on: February 07, 2013, 06:49:54 AM »
All wings need a trim tab or adjustable flaps. All of my wings are straight but that does not mean they will always fly straight.
Derek
« Last Edit: February 07, 2013, 10:58:20 AM by Derek Barry »
« Reply #10 on: February 07, 2013, 07:34:22 AM »
Remember guys, you don't have to plank the entire wing.  I plank the leading edge, with only the planking there, nothing else, plank the trailing edge, and then capstrip the rest.  Now, I am an iron on guy out of desperation to keep my ships light, so that's my approach for the wing.  I paint the fuse.
My wings on a 660 square inch wing typically weigh, with flaps and ready to cover, 12 to 13 ounces.
« Reply #11 on: February 07, 2013, 08:20:39 AM »
The Dreadnought wing with everything in it ready to cover is 10.75 oz.
My Cutlass XL wing was 11 oz.
Derek
Online RC Storick
« Reply #12 on: February 07, 2013, 08:40:31 AM »
Get a door knob saw and cut a hole every rib bay top and bottom. Secrets from the skunk works. I'm no engineer but one would think that the strength is in the skin not the foam. Much like a I beam not much strength in the wood structure till the covering goes on and it gets locked up. But heck who am I? I am just a mechanic.
« Reply #13 on: February 07, 2013, 09:41:20 AM »
There  is not much weight differance between built up and foam after they are finished, I have built 2 EXCEL SV type planes , both the same basic plane with the same wing, They both finished at 59.5 ounces 675 sq in, 60.5 in span, The foam, done properly will be about an ounce heavier befoe the finish stage, but will be almost the same weight finished, It is easier to sand the finish flat and thin on a sheeted foam wing, rather than a built up.
Also there are many advantages to foam, they are quieter, they are stiffer normally, they are more warp proof, they are easier to repair, easier to sand, easeir to buff, easier to polish...etc...
My best SV wings of the same size are 12.5 to 13 ounces built for foam, and 12 to 12.5 for built up, that is covered with covering, at least 2 coats of dope , all flaps, tips, horns, hinges, bellcrank, leadouts..etc are included. and the weights are at that stage ready to slide into the fuse
Offline Steve Fitton
« Reply #14 on: February 07, 2013, 12:08:14 PM »
It seems that my efforts are less than worthy, then. HB~>
My latest (foam)Dreadnought wing weighed 14.8 ounces with everything installed but not covered.  My first Dreadnought's wing weighed 18 ounces at that stage.  Here I thought I was making progress. n~
« Reply #15 on: February 07, 2013, 12:37:01 PM »
You are making much better progress, almost 4 ounces from your posted weights, and Your only 1.5 to 2 ounces from my best ones, With your weights you can build a 61 to 63 ounce SV, that IS  LIGHT and will fly very well at that weight.  Remember Bill had one that weighed 74 ounces in the Top 5 Flyoff years ago, and it did everything well.
« Reply #16 on: February 07, 2013, 06:54:17 PM »
Derek
Yes, come to think of it, I have a Jamison (built-up wing) old timer with a wing that is dead nuts straight (and no other misalignments I can detect with eyeball and ruler) that flies as if warped.  I would be curious to hear from Stunt Hangar's esteemed faculty of lovely and talented aerodynamikul injuneers as to what they suspect might cause such a phemommymom.  Might it be advisable to steam a warp INTO the wing in the opposite direction?  Eegad already.  Phil Cartier and others say that trim tabs are band-aid solutions that provide good trim only part of the time.
Kim Mortimore
Santa Clara, CA
« Reply #17 on: February 08, 2013, 04:31:42 AM »
It could be something as simple as a warped flap, unevenly hinged flaps, wings and stab not perfectly aligned, the list goes on and on. Phil and others are not wrong but some things have to be fixed after the fact, thats life. I would not recommend having a trim tab at a 45 degree angle, if that is the case you may want to go back and fix something but for small trim adjustments I use the trim tab.
Derek
