  • June 18, 2025, 11:12:49 PM
Author Topic: flying lines  (Read 996 times)
Offline roger
flying lines
« on: July 02, 2008, 05:41:12 PM »
hi guys
probubly been asked a thousand and one times, where can i buy flying lines? you know , like about a thousand feet to make my own lines other then brodak. thanks
roger ???
Offline Ralph Wenzel (d)
Re: flying lines
« Reply #1 on: July 02, 2008, 05:51:15 PM »
Tom Morris, MDS Supply (Mel Schuette), RSM Distribution (Eric Rule), McMaster-Carr, New Jersey Wire Rope Co. (10,000' and up), 7-Strand Corp., and doubtless many others sell the stuff. It's available in 1 x 19, 1 x 7, 3 x 7 and several other configurations. 1 x 7 is the stiffest; multi-strand stuff goes around curves more easily, but that shouldn't matter for lines.
Ralph
Ralph Wenzel
AMA 495785 League City, TX
Re: flying lines
« Reply #2 on: July 15, 2008, 09:53:32 PM »
Ditto the above. I would only suggest that you make sure you'll be getting shiny silver line, not the bronzed stuff. It's a lot easier to see in the pits, on grass or pavement, and in the air. Every little bit helps.  H^^ Steve
Offline Balsa Butcher
  • High Desert Flier
Re: flying lines
« Reply #3 on: July 16, 2008, 09:01:31 AM »
Don't forget another Stunt Hangar advertiser - CLC (Control Line Central)
Pete Cunha
Sacramento CA.
AMA 57499
