  • June 17, 2025, 02:00:06 AM
Author Topic: floating bellcrank  (Read 2388 times)
Offline Bootlegger
floating bellcrank
« on: January 30, 2013, 01:03:37 PM »
  when you're installing a floating b/c in a foam wing how do you do it and why do you do it that way??e
8th Air Force Veteran
Gil Causey
AMA# 6964
Online Trostle
Re: floating bellcrank
« Reply #1 on: January 31, 2013, 12:52:18 AM »
Floating bellcrank??
Please define.
The videos by Bob Hunt and instructions with his foam wings show very clearly how to install a light, simple, and structurally sound method to install a bellcrank in a foam wing.
Offline Bootlegger
« Reply #2 on: January 31, 2013, 04:43:35 AM »
 Keith, maybe I should have called a "suspended" bell crank.  It has an upper and lower mount, and this particular one is going in a profile model.
  Thanks for calling this to my attention.      y1
Gil Causey
AMA# 6964
« Reply #3 on: January 31, 2013, 09:20:57 AM »
Tom Morrs in his bok shows how he does it.   Also the bellcranks I have gotten show how to do it.  There is a metal rod long enough to go above and below the wing at the mountg location.   Tom Morris uses eyelets to center the bellcrank on the rod.   J-B Weld is used to hold them in place.   I do mine with wheel collars.   Grind a notch for the set screw to fit into.   The plywoo plates go on the surface of the wing top and bottom using epoxy glue.   I also now notch the rod for the epoxy to grip after losing my Spitfire.  Once the wing is in the fuselage, I cut the excess rod off almost flush with the ply wood.   I then put another layer of plywood spanning the fuselage sides top and bottom.
There are probably better ways of doing it.  Wasn't so lazy would go do a search for you. Z@@ZZZ
« Reply #4 on: February 01, 2013, 12:10:31 PM »
I just say "NO"  to floating bellcranks !!    ;D
R
Offline Bootlegger
« Reply #5 on: February 01, 2013, 04:58:55 PM »
   R,   Then say "yes" to a suspended bell crank, and 'splain how to do it    ;D
Gil Causey
AMA# 6964
« Reply #6 on: February 01, 2013, 06:10:28 PM »
I can't say how to do it in a foam wing, but I've seen pictures that make lots of sense.
Here's how you pretty much have to do it, in any wing:
  • Install the bellcrank on a rod or bolt, so that the bellcrank is held in the center of the pivot.  Lots of people use rods.  So far, I've been using #8 bolts to good effect.  I use bolt with a long smooth shank, with spacers to hold the bellcrank where I want it on the smooth shank.  Lots of people who fly lots better than me use rods -- take that as you may.
  • Install plywood (or aluminum, or titanium, or carbon fiber -- really, this is up to you) plates top and bottom that catch the spars, and that can hold the pivot in place.
  • When it comes time to install your control system, put the bellcrank in place, shove the pivot through it (and through any spacing devices you may have -- devised), and fix everything into place
Once you have the bellcrank centered in the wing on a pivot, and the pivot firmly held in the wing, everything else is details.  Have you tried digging through the various build threads to see how other people do it?
