  • June 17, 2025, 02:00:05 AM
Author Topic: Hand cleanup from epoxy glues  (Read 1723 times)
« on: August 26, 2012, 03:00:24 PM »
Guys,
Found a new cleaner for getting that sticky epoxy glue off fingers - hand sanitizer. I had tried regular detergent and it doesn't do much. I tried the hand sanitizer because I figured it had some alcohol in it so I tried it and it worked.
Best,    DennisT
Re: Hand cleanup from epoxy glues
« Reply #1 on: August 26, 2012, 03:03:06 PM »
After hearing horror stories about epoxy and cumulative toxicity -- and since I've had to significantly restrict my use of CA glues for the last 25 years -- I always wear rubber gloves.
Which makes things like fillets pretty awkward, but the cleanup is as easy as taking off a pair of gloves.
« Reply #2 on: August 26, 2012, 03:55:55 PM »
epoxy is only toxic until it it catalysed.
saying that - gloves are cheap and disposable - so I use them too.
Offline Dave Holtsclaw
« Reply #3 on: August 26, 2012, 05:03:55 PM »
Using alcohol to remove epoxy from you hands is a real bad idea. Alcohol thins the epoxy and allowes it to enter your pores more easly. Can turn out real bad. I ended up in the emergency room doing this.
Offline Wade Bognuda
« Reply #4 on: August 26, 2012, 09:29:08 PM »
Use MEK instead.
« Reply #5 on: August 26, 2012, 09:56:33 PM »
Use MEK instead.
Oh MY GOD - why would you even suggest that!!!!?
do NOT use solvents of any kind to wash epoxy off your skin - it dissolves it and makes it far easier to get INTO you blood - something you dont want to do.....
larry borden
« Reply #6 on: August 27, 2012, 06:59:49 AM »
I use the surgical gloves too.
« Reply #7 on: August 27, 2012, 11:00:55 AM »
Instead of trying solvents, which in themselves are toxic, good old soap and water works, if slowly.
« Reply #8 on: August 27, 2012, 01:11:06 PM »
   I do that sort of thing all the time. And I turned out GREAT!
steven yampolsky
« Reply #9 on: August 27, 2012, 02:06:47 PM »
The twitch and the limp are barely noticable  LL~
Offline Gene O'Keefe
« Reply #10 on: August 29, 2012, 07:43:39 AM »
Thanks Steve...I needed a really good laugh today ... almost fell out of my chair!
            LL~ LL~ LL~ LL~
Gene O'Keefe
AMA 28386
« Reply #11 on: August 31, 2012, 10:58:08 AM »
This might sound nuts, but none the less it's true.
When I donate blood, as all you fine modelers do, I ask for a bunch of surgical gloves. They don't mind giving them away to repeat donors.
There's this one blond phlebotomist, um, never mind.  ;D
Thumbs up!
Charles
Tags: glue  cleanup
