  • June 17, 2025, 08:02:13 PM
Author Topic: What size CF tube for control rods  (Read 2072 times)
« on: December 17, 2013, 07:38:48 AM »
Sorry to skip the search, but I'm on the fly, near the hs, and my go-to forum is down.
What size cf tubes and music wire for 1/2A and .35 size control rods?
Rusty
Re: What size CF tube for control rods
« Reply #1 on: December 17, 2013, 08:39:50 AM »
Well, I bought .098" ID CF tube. It has more wiggle room with 1/16" wire than I like, but with a little V bend to snug the wire, JB Weld should hold it. Hope y'all approve.
Rusty
« Reply #2 on: December 17, 2013, 10:02:12 AM »
I hope that's for the 1/2-A models.
The question is one of those whose best answer is "it depends".  I tend to use 5mm or better OD arrow shafts for big models, and 3mm OD tube for my 1/2-A models.  But I had a Fancherized Sig Twister for a very productive few months (before I stupidly crashed it) that worked great with 4mm OD rods.
I decide whether a rod is stiff enough by pressing the ends together -- if the rod bows enough that I can feel it get springy, then I use something bigger.
« Reply #3 on: December 17, 2013, 10:29:06 AM »
This is 4mm OD x 2.5mm ID, so the wall is 1.5mm thick. I do have a 1/2A use for it, but I was hoping to use it on the Sterling Yak-9. It feels pretty stiff, but I haven't cut it yet so it's hard for me to tell. I'll decide when I do the springy bow test. Thanks, Tim.
Rusty
« Reply #4 on: December 17, 2013, 06:56:05 PM »
Rusty
0.75mm -- remember that as you go through the middle of the tube you hit the wall twice.
That should work just fine.
« Reply #5 on: December 17, 2013, 08:59:00 PM »
0.75mm -- remember that as you go through the middle of the tube you hit the wall twice...
Uh, Duh, yeah. ::) It's measuring mistakes like that that keep me from being an expert builder. Measure 4 times, cut once, throw it in the trash.
Offline Phil Krankowski
« Reply #6 on: December 19, 2013, 06:57:49 PM »
Sounds like you need to do more draw a picture first, then draw how you will measure the picture.  Make a mock-up if necessary...
 ??? ::) reminds me of physics class :-\
Phil
