  • July 17, 2025, 09:36:13 AM
Author Topic: Flap Torque Tube  (Read 1627 times)
Flap Torque Tube
« on: March 08, 2010, 09:34:36 AM »
Has anybody else tried this type of flap construction?  The leading edge was backed with two layers of 5gr. carbonfiber matte and epoxy, and then carved to shape.  Built the flap up flat on the board, using 1/16 in. sheet surfaces and ribs, with a ply root rib slotted for the horn.  Shaped the leading edge and sanded it down to the skins, rounding the corners a bit to avoid later sanding through the carbon fiber.  Then wrapped a couple layers of matte around the leading edge and covered the flat surfaces with one layer.
The end result is a flap with a pretty stiff torque tube at the leading edge with the carbon fiber boxing in the leading edge, supplemented by a sorta torque tube formed by the surfaces of the flap.
It's a bit more work than carving from a solid sheet, but seems to be lighter and and stiffer.  All the wood on the inside of a flap doesn't do much for stiffness anyway.
Re: Flap Torque Tube
« Reply #1 on: March 08, 2010, 10:06:17 AM »
It certainly looks like a winner.  Carving a flap out of a single piece of solid wood will probably get you the worst possible stiffness/weight ratio.  The carbon fiber should stiffen things up dramatically -- I assume you use mat with random fiber directions, but if you use cloth you should run the fibers diagonally to line of flight (45 degrees if it's woven at right angles).
It'd be interesting to see someone build flaps in several different ways, then measure torsional stiffness and weight.  Covering should not be ignored!  I can see several different ways that could be investigated:
1.  Plain ol' wood.  This is probably the worst.
2.  Plain ol' wood with silk on a 45 degree bias.  Should strengthen up, but I dunno how much.
3.  Plain ol' wood, silk on 'straight' -- if silk on a 45 degree bias makes a difference from plain wood, this will be better than plain wood, worse than 45 degree.
4.  Plain ol' wood, silkspan.
(if you're thorough, you'll try different weights and or multiple layers)
5.  Plain ol' wood, carbon fiber.  Anything with significant CF should be way stiff, but fragile if you really twist it, particularly if you stick the CF on with dope.
6.  "balsa plywood" -- stick two sheets together with grain offset by 30 degrees or so, so that top and bottom grain both run mostly along the flap, but at a 15 - 30 degree angle.  Then sand it out like plain ol' wood, with the glue joint down the center.  I would expect this to be significantly stiffer than plain ol' wood.
7.  Built up -- leading edge like yours, ribs, sheeting.
7a.  Built up, diagonal -- Run the ribs diagonally to make triangle pattern, sheet.
7b.  Built up, diagonal, no sheeting.  Done right I bet this'll be stiffer than plain ol', and it'll be lighter with careful glue management.
7c.  Built up, with CF -- this is, I think, what you're proposing.
8.  Foam core.  Like yours, only with foam instead of ribs.  Probably more trouble cutting the core than it's worth.
8a.  Foam core with/without CF.
As a control you could mill a flap out of tungsten.  It'd be stiff, but I think the weight would disappoint.
If building and testing 12 different flaps weren't enough, there's going to be a distinct tradeoff between flap thickness and torsional stiffness.  Who wants to make 24, 36, 48 flaps?
« Reply #2 on: March 08, 2010, 03:20:41 PM »
Talk to Howard Rush about this. He does some very interesting stuff with flaps and torque tubes.
« Reply #3 on: March 09, 2010, 09:09:48 AM »
Hope I can get by with this.  Go over to the stuka stunt works site and do a search on Al Rabe's construction of his various planes.  He has quite a bit about stiffening up the flaps/elevators.   Good idea tho Phil. H^^
Online Martin Quartim
    • StuntHobby
« Reply #4 on: March 09, 2010, 08:22:21 PM »
I have discussed and sent Howard a drawing very similar to this one.
I think it is better to do exactly how Howard makes his carbon tubes because it will be lighter.
What I have been thinking is how to make the tubes with a built in hinge, to avoid cutting the tube to install a regular hinge.
Martin
Offline Allan Perret
  • Proverbs
« Reply #5 on: March 11, 2010, 06:37:56 AM »
I like this method but, the downside is that after you build in this nice torque tube you have to notch away about half of it at each of the hinge locations.
I would think that in the end you will retain less than half of the added stiffness this method built in..
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #6 on: March 11, 2010, 08:42:13 AM »
I don't think so Allen, the carbon is completely bonded to the surface, in order to lose stiffness it would have to become unbonded and even then if there was enough resin it would retain much of its stiffness. Wakefield wings are built with D-tubes made of CF with ribs and no leading edge. The CF is bonded to the ribs and spar leaving much of the surface self supporting. The torsional stiffness of these wings is astounding. That's the beauty of CF, once it is constrained to a shape via resin or otherwise adhered, it becomes tremendously stiff.
