  • May 23, 2024, 09:18:31 PM
Author Topic: Flap horn on a Profile.  (Read 1718 times)
Online Airacobra
« on: January 26, 2009, 08:04:18 PM »
Just out of curiosity, can some of you show the setup you use on a profile. I have seen some folks use the standard plastic horns and others using something like the Morris offset horns. I was hoping some of you guys could shed some light on your technique.
Keith Bryant
Online Crist Rigotti
Re: Flap horn on a Profile.
« Reply #1 on: January 26, 2009, 08:37:46 PM »
Keith,
I use an offset horn.  The pictures says it all.
Online Airacobra
« Reply #2 on: January 26, 2009, 10:05:45 PM »
Yes it does Crist, Thank you for the post.
Keith Bryant
Offline Greg L Bahrman
« Reply #3 on: January 26, 2009, 11:24:57 PM »
here ya go
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Online Airacobra
« Reply #4 on: January 27, 2009, 07:03:11 AM »
Thanks guys, the input has been very helpful.
Keith Bryant
Offline Russell Shaffer
« Reply #5 on: January 27, 2009, 09:56:02 AM »
Would either of you guys have a picture of your setup before covering?  Thanks
Russell Shaffer
Klamath Falls, Oregon
« Reply #6 on: January 28, 2009, 09:31:58 PM »
One of the bigger problems with the nylon R/C horn is that it's usually attached to the inboard flap. Then, the flap joiner wire has to receive & transfer the torque to the outboard flap. With the horns shown, the lever applies the torque to the wire, then both flaps. If anything, you'd want to apply the torque to the outboard flap...might eliminate the need to use a 'wart' on the outboard flap, ya know. For the same reason, it would be logical to have the flap horn on the outboard side with any sort of flap horn...the outboard torsion bar being shorter.
Anyway, most those R/C horns are just too flexible, so if you just have to use one, get one for Giant Scale and mount it on the outboard flap. Give it a flex test, if you can. Glass fiber reinforced nylon would be ideal. Cheapies will not be a good choice. I'd be glad to use 1.25" at both flap and elevator. You can use one bolt through both ball ends at the flap. Put the elevator pushrod closest to the fuselage, to reduce the pushrod/flap interference. Adjust the control ratio to suit the plane's weight. Don't fail to experiment with this, you'll learn a lot!  mw~ Steve
Online Dennis Moritz
« Reply #7 on: January 29, 2009, 07:34:15 PM »
On Alan Brickhaus' recommendation I doubled the horns on my Twister. Guess it helps.
« Reply #8 on: January 29, 2009, 08:50:08 PM »
That'll work! Another good option is the long steel Sullivan control horns. Given some time, I could come up with a Pn., but not real soon. Gotta try to get ready for flying Saturday. Tower stocks them, so you can look 'em up in their big cattledog.  n~ Steve
« Reply #9 on: January 30, 2009, 02:00:39 PM »
I would usually use an offset horn like those shown, but the current profile I'm working on, well, that's really not going to be an option. So I'm planning to use an aluminum inset into the flap (with appropriate reinforcement) and music wire for the connection between the flaps. Sigh...
