Be sure to mark which surface is up, as mine varied, depending on how they were rotated. Once you have a set that matches, you are golden!
I still prefer my widgets, the longer the rods, the more sensitive they are. Mine are roughly 6 in long, but the next set will be about 8 in. And more attention paid to really accurate construction. They will be set in holes in the base of the angle stock and carefully set to vertical relative to the bottom surface. I am sufficiently pleased with the widgets to make a real precision set, probably 4 units.
The first ones certainly did the job I needed, but having that success, why not go for a really precision setup? Once made, forever available!
