Jack...FWIW, I would
never ever hang a tab or rudder on pieces of tubing, bending the tubes to make an adjustment. One little bump, and your adjustment is gone. I'd suggest using some sort of hinges and adjuster scheme on any tabs or the rudder. Pretty much your choice as to what sort, but the Robart "hinge points" and "horney hinge points" seem particularly useful for this.
Based on what Brett and Howard are preaching (i.e., do what you have to, to make it straight), one thing you can do on the field to do a "quick and dirty" is to tape some trailing edge stock onto the bottom of the TE. Thick edge aft, inboard wing if it's low, outboard wing if it's low. This you can do on the first flying session, to allow you to get more than one flight in, and get your engine/tank/prop sorted out to some extent. It's an old free flight trick, but works fine on CL models.
