  • July 08, 2025, 10:22:54 PM
Author Topic: Fitting a canopy  (Read 1834 times)
Offline James Mills
Fitting a canopy
« on: January 22, 2008, 06:13:16 PM »
I'm making progress on my Formula S and one thing I still haven't been able to get the knack of is cutting a plastic canopy down to fit well on the the top block HB~>.  I'm to the point of just carving the canopy on this one and moving on.  Do any of you have any shots of how to do this?
James
AMA 491167
Offline Leester
Re: Fitting a canopy
« Reply #1 on: January 22, 2008, 07:04:31 PM »
I just put the canopy on the plans side view and mark it with a sharpie and cut it. It usually gets it close enough.
Leester
ama 830538
« Reply #2 on: January 22, 2008, 07:20:18 PM »
if yoru top deck is a block, and has enough thickness, you can carve a little channel that it sits in, this helps "hide" some of the not perfect fit. Do you have a set of the scissors for cutting canopies, man they help a ton! Another thing I do is to tape a peice of sandpaper, somthing like 150 grit, on the top of the fuse where the canopy sits and use that to help sand the edges into shape.
Offline Leo Mehl
« Reply #3 on: January 22, 2008, 08:05:18 PM »
I cut a groove or a ledge all away around the area that the canopy sits. I cut a groove in the nose block so canopy will fit. I usually glue it in place and tape around it and use filler to make the conopy look like it is part of the fuselodge. I also put a narrow strip of silkspan all the way around to help make it a little more secure
Offline James Mills
« Reply #4 on: January 22, 2008, 08:47:36 PM »
I'm using regular scissors, is there a certain kind made for cutting canopies?
James
AMA 491167
« Reply #5 on: January 22, 2008, 09:30:01 PM »
James,
Here's a trick, but you have to promise you will keep it in the secret society of canopy cutters.
Cut the canopy so it's in the neighborhood of the right size. May take several fittings to get it close. Then take some sandpaper and cut it to fit the area the canopy fits (several pieces are OK) and use some spray contact cement like 3M-77 glue the sandpaper down with the rough side up. I usually use something like 100 grit stuff. The put the canopy in place and move it back and forth until it fits the curve of the area. Should have some fairly sharp edges. Once it's fitted to the top block, pop the sandpaper off and clean the area (usualy not too hard). Put the canopy on and trace around it. Cut a slot for the canopy to fit in (as Leo said - hey, he does have a good thought every once in awhile - :)  ) The canopy should slide right into the slot.
And there you are; a fitted canopy.
Offline Balsa Butcher
  • High Desert Flier
« Reply #6 on: January 29, 2008, 08:10:12 PM »
RE canopy scissors:  Slot car guys use small, slightly curved scissors to cut their race car bodies which are made of a similar plastic.  They work well.  Not too many slot car tracks around anymore but the scissors could probably be found on line.
Pete Cunha
Sacramento CA.
AMA 57499
Offline Mike Spiess
  • bikemike
  • AMA #4060
« Reply #7 on: January 30, 2008, 08:59:33 AM »
I use a fingernail scissors I got from my Mom she was a nurse.
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
« Reply #8 on: January 30, 2008, 09:08:47 AM »
rc car guys use them too, i got a set in one package, like 12 bucks? straight blade and curved blade sets
« Reply #9 on: February 01, 2008, 09:56:35 AM »
I wouldn't worry TOO much about cutting through the blocks when installing the canopy.  Using epoxy in the slot and filling it up with the canopy pretty much takes care of that problem.  Plus we all cover the nose with fiberglass or CF so that keeps things from cracking, at least in my cases.  My 11 year old *regular* PAMPA plane has a bunch of *holes* where I cut through the top block attaching the canopy! LL~  LL~  No cracks, etc., yet...........
Offline Tom Niebuhr
« Reply #10 on: February 02, 2008, 12:47:09 PM »
Leo,
It is great to some more cockpits. What does the rest of the airplane look like?
AMA 7544
« Reply #11 on: February 02, 2008, 05:18:13 PM »
I rough them out with curved scissors, then I stick Great Planes 220 grit papter on the fuselage and sand the canopy into a perfect contour fit, I don't groove the blocks.
Offline Leo Mehl
« Reply #12 on: February 07, 2008, 10:41:02 PM »
Leo,
Pictured on Open Forum. Two Down and One to go. OR
