  • August 03, 2025, 05:47:00 AM
Author Topic: Mig-3 Building Techniques  (Read 103342 times)
« on: June 27, 2015, 09:06:25 AM »
Just thought I'd drop in a few photos of the building techniques progression on the semi-scale stunt Mig-3's nose area.
I look at the nose completed and painted and sometimes forget the stepts it took me to get there.
As with any completed model, I sometimes look back and can't believe I actually "did that."  ;D
« Last Edit: June 15, 2016, 05:31:51 PM by Avaiojet »
Online Carl Cisneros
Re: Mig-3 Building Techniques
« Reply #1 on: June 28, 2015, 02:48:30 PM »
Charles
I wish I could build and paint like you....................  H^^ H^^
Just Beautiful
Carl R Cisneros, Dist IV
Control Line RB
« Reply #2 on: June 28, 2015, 02:56:44 PM »
Charles
Just Beautiful
Carl,
So do a lot of others.  LL~ LL~ LL~
Carl, you're so kind and thanks for the boost. It's appreciated
Ya know Carl, it's actually not as difficult as it looks.
Thanks for the reply.
« Reply #3 on: June 29, 2015, 10:49:18 PM »
Charles;
If I tried to do that it would wind up looking like Earl Shibe did it....................
Remember those commercials?  I will paint any car any color for 29.95............. (believe it was mostly west coast tho)
Control Line RB
« Reply #4 on: July 03, 2015, 05:55:41 AM »
Charles;
Carl,
We had Earl Shibe on the east coast also, but by the time they arrived it was 49.95.  LL~ LL~ LL~
FYI. That's all water base artist's acrylic, on the Mig-3.
« Reply #5 on: July 13, 2015, 12:24:35 PM »
Someone mentioned tape dwell time, leaving it on long and all, and that got me thinking.
This fine line tape has been on the Mig-3 for quite some time, possibly a month.
Started masking for the yellow underbelly.
Be pointless to remove it and remask, fine line tape is costly.
« Last Edit: June 15, 2016, 05:33:24 PM by Avaiojet »
« Reply #6 on: August 01, 2015, 07:17:47 PM »
I'm lost as to where to Post this, the Mig-3 really isn't scale and it really isn't a stunt ship.
It does resemble a Mig-3 aircraft and it will stunt, probably poorly because it will be about 54 oz with only 50" of span.
All surface detail has been experimental for the benefit of future efforts with the Stuka tank buster.
I used vinyl for this surface detailing. Just enough yellow to cover and close the rivets in and I'm done with the Mig's bottom.
Still have a ways to go.
BTW. All this paint is water base.
« Last Edit: June 15, 2016, 05:35:10 PM by Avaiojet »
« Reply #7 on: August 02, 2015, 10:06:11 AM »
BEAUTIFUL, JUST BEAUTIFUL!!!!!!!!!!!!   H^^ H^^
Control Line RB
« Reply #8 on: August 03, 2015, 05:24:23 AM »
Carl,
Your just too kind and a double hats off to boot.  #^
Wow! What a boost.
I have only bits and pieces of detail left to do on the underside, small stuff that's time consuming because I have to lay the art out in CAD then cut the pieces. Hatches and stuff.
I'll use vinyl.
Next half dozen days should show just about finished results for the bottom.
Then it will be the wing and fuse top color which is the last color before graphics.
I'm excited.
Thanks for the reply and interest.
Offline frank mccune
« Reply #9 on: August 03, 2015, 06:56:01 AM »
     Hi Charles:
     As always, beautiful work! Continue posting the pictures.
     The next time that you do a canopy installation, kindly post a "how to" as I can not seem to obtain an attractive appearance of the joint between the fuselage and canopy.
        Be well my friend,
        Frank
« Reply #10 on: August 04, 2015, 09:19:12 AM »
     Hi Charles:
        Be well my friend,
        Frank
Frank,
I'm not the canopy guru.
There are others that bring clear canopies to life much better than I do.
Many of them don't have toothpicks.  LL~ LL~ LL~
The canopy install on the Mig-3 is someplace? I lose track.  n~
Online RC Storick
« Reply #11 on: August 04, 2015, 02:28:58 PM »
    Hi Charles:
        Be well my friend,
        Frank
« Reply #12 on: August 05, 2015, 05:11:01 PM »
Robert,
Just saw your reply Post.
Excellent work as usual.  H^^
Thanks for Posting those great videos.
Robert, I see your work and all I can think of is that James Bond song, "Nobody does it better."
Outstanding!
« Reply #13 on: August 17, 2015, 09:17:01 AM »
Hey ya;
Just sent ya an e-mail concerning another plane Charles.   :-)
Carl
Control Line RB
« Reply #14 on: April 12, 2017, 05:31:47 PM »
Hey ya;
Carl
Carl,
I just saw this, where have you been?
CB
