  • August 01, 2025, 09:13:02 AM
Author Topic: Fillets  (Read 2077 times)
Offline JackComer
Fillets
« on: October 24, 2006, 05:14:35 PM »
What do you all like to use to make your fillets for the wing,stab and around the canopy? Aero Poxy lite,Sig epoxilite,leather fillets or what???
Thanks in advance.
jack Comer
Jack Comer
AMA 129715
Online RC Storick
Re: Fillets
« Reply #1 on: October 24, 2006, 05:52:06 PM »
Thanks in advance.
jack Comer
see tip section http://www.stunthanger.com/tips.htm
Offline JackComer
Re: Fillets
« Reply #2 on: October 24, 2006, 07:05:13 PM »
ROBERT
  Thank You. Do use use the same method for the wing and stab Fillets? That is  epoxilite and micro balloons? The helpful hints just gave your method for the canopy.
Jack Comer
AMA 129715
Online RC Storick
Re: Fillets
« Reply #3 on: October 24, 2006, 07:56:52 PM »
Same for wing and stab. Yes Epoxolite and micro-balloons
Offline Ron Merrill
Re: Fillets
« Reply #4 on: October 25, 2006, 08:47:57 AM »
Jack, i use Aero Poxy Lite, it is very lite,strong and very easy to sand, but!!!!!!!!!!!!! you must use a gram scale and weigh it, to get the correct amts. Ron.  AP^
Re: Fillets
« Reply #5 on: October 25, 2006, 08:49:09 AM »
Sparky,
 So does this mean you're mixing micro balloons into your Epoxolite sometimes?
 I've always shyed away from Epoxolite because when I used it years ago, I remember it being hard as a rock after curing, and very difficult to sand. Maybe micro balloons is the secret?
Offline Ron King
Re: Fillets
« Reply #6 on: October 25, 2006, 01:00:40 PM »
 I've always shied away from Epoxolite because when I used it years ago, I remember it being hard as a rock after curing, and very difficult to sand.
Epoxolite does dry hard, but is easy to wet sand. I use 320 wet and it smoothes out just fine.
Maybe the trick is to get it smooth when you put it on. Some guys dip their fingers in alcohol, but I prefer water. Alcohol is a thinner for epoxy and I don't want to thin or slow down the set time. Keep dipping and smoothing and the Epoxolite fillets will be almost ready for finish when they dry.
I found Aeropoxy to be too finicky for my use. It must be weighed accurately with a gram scale and that's too much trouble. You can eyeball the portions for Epoxolite and it cures much faster.
Ron
Ron King
AMA AVP District 4
Wannabe Stunt Pilot since 1963
 Amateurs practice until they get it right; Pros practice until they cannot get it wrong.
Online RC Storick
Re: Fillets
« Reply #7 on: October 25, 2006, 01:14:50 PM »
Sparky,
I mix the Epoxolite 50-50 by weight. Then I add about 50% by volume of micro balloons. Be careful as the micro balloons will cause it to kick off FAST!! So only mix what you can work in 10 minutes.
