I started a new build today. I decided to build from scratch, rather than having the parts laser cut. I took pictures to illustrate the process and offer them here for whatever the value it may be to help my fellow modelors.
The plane is a design for a Fantasy Scale Stunt plane, called Zweipanzerflug. I've posted some info on it before.
I always draw a pattern sheet for the parts. The trick is to cut the patterrns out and use a light coating of 3M77 to stick them to the wood. Notice that the parts are all laid out as they would be on each individual sheet of wood.
Next, useing a band saw for the larger parts, and a dremel scroll saw for the smaller ones, I'll cut out the individule parts themselves. I don't try to cut exactly to the lines. I'll use the disk sander for that chore.
A few houirs of enjoyable work, and I have a kit.
I store associated parts together in plastic baggies. It helps me keep track of them.
