  • June 18, 2025, 08:30:08 PM
Author Topic: Silicone Sealant/Glue/ or ? Problem  (Read 1256 times)
Offline Ward Van Duzer
« on: June 13, 2008, 08:10:40 AM »
OK, we all use it in our shops, around the house, as a flexible glue, a bedding compound for tanks, tuned pipes, gaskets, etc..
But how do you keep it from "drying out" in the tube? No matter how I seal the tube (with the screw top, an elastic cap, or a piece of music wire shoved down his throat) within a few months I have a solid tube of cured silicone! Useless! Right now I probably have 3-4 tubes of this stuff fully cured in the tube. No, not Brand X, or other cheap stuff, but the GE Silicone II.
Anyone have a cure for this? (An unintended pun)!  :!
W
Offline Steve Kocher
Re: Silicone Sealant/Glue/ or ? Problem
« Reply #1 on: June 13, 2008, 10:33:30 AM »
Try enclosing it in an air tight container.  I used to have a problem with CA only lasting a few days before it was solid as rock.  I started putting it in an air tight container from Walmart and it has lasted for over 6 months.
Steve.
Steve Kocher
AMA 388654
Offline don Burke
« Reply #2 on: June 13, 2008, 10:47:23 PM »
RTV (room temperature vulcanizing) silicone "cures" by reacting with moisture.  The vinyl plastic tubes that it is usually sold in are sieves as far as water is concerned, setting up is inevitable.  Got to keep the water away from it.  The sealed box sounds like a good idea, that would at least slow it down.
don Burke AMA 843
Menifee, CA
« Reply #3 on: June 14, 2008, 02:31:28 PM »
What Ty said.
Offline John KruziK
« Reply #4 on: June 14, 2008, 04:34:52 PM »
I use all types of caulk for work. We usually seal end with masking tape after squeezing air out of tube. I have saved caulk for several months this way. John
AMA 874027
Offline Leester
« Reply #5 on: June 14, 2008, 05:43:56 PM »
Hope I don't jinx myself,  but I opened and used and closed a tube of Permatex clear RTV Silicone adhesive sealant over 2 months ago. I just checked it and it is just like it was when I first used it, A OK.
Leester
ama 830538
« Reply #6 on: June 15, 2008, 08:34:13 AM »
RTV doesn't seem to have the same problem. I've been using some for years sealing headers/mufflers...
W.
Edit: Specifically that's Loctite High Temp RTV Silicone Gasket Maker...
« Last Edit: June 15, 2008, 02:22:44 PM by Ward Van Duzer »
