  • July 08, 2025, 03:52:42 AM
Author Topic: FG Vs CF  (Read 2333 times)
FG Vs CF
« on: March 26, 2016, 04:26:26 PM »
If you mold a part from FG and one from CF which one would weight more?
  • Gravitywell
Re: FG Vs CF
« Reply #1 on: March 26, 2016, 04:33:44 PM »
Everything else being equal....fiberglass would be heavier. H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline Target
  • C/L Addict
Re: FG Vs CF
« Reply #2 on: March 27, 2016, 01:05:35 AM »
Using the same weight of fabric, the parts should weigh the same. The carbon part of the same weight will be stiffer and stronger in tension.
Because carbon is stiffer, the same parts made out of glass need more material, which takes more resin, and that makes them heavier.
But if you used a single layer of 6 oz glass or 6 oz carbon to mold a part, they should weigh the same.
R,
Chris
Chris
AMA 5956
Offline Serge_Krauss
Re: FG Vs CF
« Reply #3 on: March 28, 2016, 08:29:15 PM »
I found that there was more empty space in my CF veil that in .56-oz class cloth. My FG part came out marginally lighter. This, however, was not in molds, but rather in surface lay-ups where minimum resin was left after rolling and scraping. - SK
Offline Lauri Malila
Re: FG Vs CF
« Reply #4 on: March 28, 2016, 11:39:53 PM »
..and if you compare the lightest (.56?) glass cloth with slightly heavier, say 1..2oz, you will notice that the heavier have much less epty holes in the weave. Again, much stiffer than the lightest with about same weight gain. And, unlike the lightest, they even allow some sanding. L
