  • June 19, 2025, 11:35:18 AM
Author Topic: Horn wire size  (Read 1256 times)
Offline Allan Perret
  • Proverbs
Horn wire size
« on: July 13, 2011, 03:48:26 PM »
For 60 size stunters.
Been in habit of using 1/8" wire horns for both flap and elevator.
Been thinking that 3/32" would be OK for the elevator, and stay with 1/8" wire horn on the flaps.
What say you ?
Allan Perret
AMA 302406
Slidell, Louisiana
Re: Horn wire size
« Reply #1 on: July 13, 2011, 04:12:36 PM »
When I braze up my own horns, 3/32" is OK for elevator if the span is not more than 1" each side of the horn. Of course, smaller models would get by with even less wire.  Span on flap horns is usually greater, so 1/8" is called for there.
I once made the mistake of using a CF rod for flap wire.  Not good.  Inside an aluminum tube, it did nothing but bind!  Had to tear it apart and install good old piano wire.
Re: Horn wire size
« Reply #2 on: July 13, 2011, 10:00:03 PM »
Allan,
That's what I use.
Re: Horn wire size
« Reply #3 on: July 15, 2011, 07:35:13 PM »
I use 1/8 when I make my own, as Randy does, but I have been using drill rod instead of piano/music wire because it is bullet proof, but more easily tweaked.  No fellas, you can't tweak it accidentally, it's still too stiff for that.  But you stand a much better chance of not busting a flap.
