  • June 17, 2025, 07:44:30 AM
Author Topic: Epoxy mixing tip  (Read 1407 times)
steven yampolsky
Epoxy mixing tip
« on: October 31, 2012, 06:15:37 PM »
I've recently learned about a tip full size kit plane builders use when mixing epoxy. I think you will find very useful:
After you've mixed up a batch, pour it into a fresh container before using it. No matter how much stirring you do, there will always be some unmixed resin stuck to the walls of the mixing cup. Pouring epoxy into another cup will ensure no unmixed resin ever gets on the model.
Re: Epoxy mixing tip
« Reply #1 on: October 31, 2012, 06:44:40 PM »
And here's an epoxy mixing tip from the Jive Combat Team: be sure to mix it.  When you leave out one of the parts, it doesn't work very well as glue.  I built some flaps last year that never got stuck together, even after a week in the light box.
steven yampolsky
« Reply #2 on: October 31, 2012, 07:47:32 PM »
 LL~ LL~ LL~ LL~ LL~ LL~
« Reply #3 on: October 31, 2012, 08:39:54 PM »
Yes, folks, that's our Howard. Our very own absent minded professor.
« Reply #4 on: October 31, 2012, 09:43:39 PM »
 Howard could not possibly make that mistake, I'm certain it was intended as a potential weight saving measure. :)
