  • August 01, 2025, 10:05:54 PM
Author Topic: epoxy for general building??  (Read 1247 times)
Offline Jim Oliver
« on: March 13, 2007, 09:36:30 PM »
Hey guys,
Since Hobby Poxy (my old favorite) is no longer available I have floundered about trying to find a good epoxy for general building.  Presently using Z Poxy but don't like some things about it--turns yellow and gets grainy.
What is the best for general building use?
Jim
Jim Oliver
AMA 18475
Offline Ralph Wenzel (d)
Re: epoxy for general building??
« Reply #1 on: March 14, 2007, 01:46:18 AM »
I just started using West Systems Epoxy with both the "Fast" and "slow" hardeners. I really like everything about it, so far. If you do go this way, be sure to get the appropriate pumps. Both hardeners mix with the resin ar a 1:5 ratio (5 parts resin to 1 part hardener), and it works by Volume or by Weight.
I do keep all the resin/hardener cans in a small box lined with paper towels to catch drips, but there haven't been any! Set-up times and Cure times are very close to the claimed performance. Temperature is important: Use the Slow Hardenerwhenever the temp is above 70, or pot-life will grab you. Likewise, use the Fast Hardener whenever temps are under 60, or set-up time is excessive.
Observe warnings regarding total volume, containers, and cleanliness and you'll be OK.
Ralph Wenzel
AMA 495785 League City, TX
Offline Mike Ferguson
« Reply #2 on: March 14, 2007, 10:13:05 AM »
Either West Systems or EZ-LAM.  They're essentially the same - and both are fantastic to use.
« Reply #3 on: March 14, 2007, 10:22:28 AM »
Hey guys,
Jim
Hi Jim,
Are we talking gluing ply fuselage formers (F-1, F-2), gluing bellcrank mounts/supports, etc.,  or "laminating" with epoxy?
I use the Smith Products (usually relabeled for the shop selling it) for all the "gluing" situations; 5, 15, or 30 min. types.   Never had a problem there.
Haven't used the West Systems for laminating, but hear it's excellent.  I still use Z-Poxy for f/g ellipses on foam wings, laminating "balsa/CF/balsa" nose doublers, etc..
Bill <><
