  • June 19, 2025, 03:56:54 PM
Author Topic: epoxy applicators?  (Read 2317 times)
Offline Steve Thornton
epoxy applicators?
« on: January 11, 2012, 09:28:06 AM »
Anyone have a technique for applying epoxy to fuselage formers, motor crutches, etc.?  Are there applicator tubes or devices to use?  I use an old drivers license to spread it thin but I seem to wind up with the stuff all over my hands and work area, which leaves prints on the plane.  Bad news if my nose itches.
Thanks Steve
"Most of us won't make it out of this world alive."
Steve Thornton
Re: epoxy applicators?
« Reply #1 on: January 11, 2012, 10:55:44 AM »
Steve,
I use nitrile gloves. And a dental tools like the ones pictured for applying it.
« Reply #2 on: January 11, 2012, 12:16:21 PM »
Naw.  I use a 12" flexible machinist's ruler (stainless steel).  Great for mixing and spreading.
But I sometimes have to scrape the cured epoxy off the end if I want to measure something. (not often)
« Reply #3 on: January 11, 2012, 12:22:02 PM »
Hi Steve,
For wide areas,  I take a piece of scrap 1/16th" ply about 3" wide and use the band saw or scroll saw to cut small notches along the edge.  In other areas I use cotton swabs (Q-tips) or acid brushes like plumbers use (both being disposable)..
BIG Bear
RNMM/AMM
Offline Rafael Gonzalez
« Reply #4 on: January 11, 2012, 01:05:11 PM »
I go to the typical HD, Walmart,etc. or a car part store. Find the stiff body putty applicators (usually 2 or 3 bucks for a set) then throw them away if you wish. The epoxy goes on easy. The other alternate is a 6" putty knife for joint compound. This is what my preference is for spreading any glue on large flat areas. Just make sure on this one, you wipe everything off! HB~> HB~>
 D>K
Offline Dick Pacini
« Reply #5 on: January 11, 2012, 01:27:43 PM »
Popsicle sticks work well.  You can either save them from your freezer treats or you can buy a bag of them from any craft store.  Some hobby shops carry them too.
AMA 62221
Offline John Desrosiers
« Reply #6 on: January 11, 2012, 04:48:07 PM »
I use 1 inch foam paint brushes. Pull the foam brush off  and you will have just what you need.  get them at home depot or walmart for less than 50 cents.
« Reply #7 on: January 11, 2012, 05:01:32 PM »
I use nitrate gloves for everything - cant stand glue of my fingers at all.
I found a photo of Randy in his workshop.
Offline Guy B Jr
« Reply #8 on: January 11, 2012, 11:03:04 PM »
Artists who paint with oils have a spatula that is just what we need and that gave me the idea. So I took a stainless steel flatware table knife and bent two bends to make it an angled spatula.
Kind of like this.
Guy Blankinship
Offline Douglas Ames
« Reply #9 on: January 11, 2012, 11:29:32 PM »
Scrap Balsa? Works for me.
AMA 656546
Offline louie klein
« Reply #10 on: January 12, 2012, 06:27:20 AM »
All of the above plus some wax paper laid out to protect what ya wanna protect.----LOUIE  H^^ H^^ D>K
Offline Ward Van Duzer
« Reply #11 on: January 15, 2012, 11:52:37 AM »
Popsicle sticks or solder brushes for application. You can shape the tips to match your situation. Buy a box of thousands in an art supply store for peanuts. Don't pay $3.00 a dozen.
OR
Don't you guys get hundreds of fake credit cards in the mail? These are great spreaders. You can notch them like glue trowels
if you feel the need.
Ward-O
« Reply #12 on: January 15, 2012, 12:26:35 PM »
I bought a set of dental "spatulas" at some expo show years ago. They ran from about an 1/8" wide to an 1" with a square end on one end and a rounded one on the other. Good for all kinds of stuff but I mainly mix fillers and epoxy with them and use them for applicators. The 1/4" wide one is the most often used.
« Reply #13 on: January 15, 2012, 01:15:59 PM »
Signature Inn room keycards!
Offline Joseph Lijoi
« Reply #14 on: January 19, 2012, 10:03:00 PM »
Playing cards are great for this.  I use them for mixing small amounts of glue and as applicators.  They also make great shims for jigging, are disposable and can be cut and laminated to suit.  Fairly cheap and you can get them at the casino for free after you loose your ass at black jack!  This really puts your cost effectiveness ratio in the can!  It doesn't help that I am superstitious and will only use dueces and face cards suited hearts or diamonds.
