  • July 08, 2025, 02:30:27 PM
Author Topic: Envoy Scratch Build (Wings)  (Read 4561 times)
Offline Peter Walker
  • Dadda
« on: March 07, 2015, 05:30:37 PM »
Hello everyone
I have decided to scratch build an old Envoy. However, I seem to be having a problem with the wing assembly. No matter what technique I try with it I cant seem to get the ribs to line up on either the LE or TE. I checked that the material is all straight and true and that all my ribs are exact according to the rib patterns on the plan. It's all 100% straight and true.
I have tried setting it up with wing jigs, but cant see to get all the ribs exactly level with the top of both the leading edge and trailing edge.
I am really open to any and all suggestions please.  ???
You never know what is around the corner.
Re: Envoy Scratch Build (Wings)
« Reply #1 on: March 07, 2015, 06:07:46 PM »
This Envoy?  http://www.outerzone.co.uk/plan_details.asp?ID=4787
How did you cut the ribs?  From the plans, it seems to be a fairly straightforward build, except that it's not terribly "jiggable".
  • Dadda
« Reply #2 on: March 08, 2015, 01:10:57 AM »
Yes Tim, that is the one.
Offline Jim Svitko
« Reply #3 on: March 08, 2015, 11:40:15 AM »
If I understand your problem, some of the ribs protrude from either the top or bottom of the leading and trailing edges?  Or, the ribs do not even reach the top or bottom of the leading or trailing edge, therefore leaving a gap (hole?) that then has to be filled.
And, you say all parts are true an straight?  The only thing I can come up with right now is that maybe the rib profiles on the plans are not drawn perfectly symmetrical.  That might account for not being able to get the ends of the ribs to match the leading and trailing edges.
« Reply #4 on: March 08, 2015, 01:40:23 PM »
the ribs drawn on the plan are NOT accurate  - take the root rib and tip rib and make your own set using those as a template - I had the same issue until I measured all the ribs and found the error
« Reply #5 on: March 08, 2015, 03:13:21 PM »
Wynn beat me to it.   If you make the root rib and tip rib out of plywood you can then make as many rib sets as you want.   Also if lined up right, depending on straight leading or trailing edge, you make the jig holes.
  • Dadda
« Reply #6 on: March 09, 2015, 12:19:34 PM »
Thanks a lot for the advice guys. Will most certainly follow that bit of advice. One tends to take for granted that if its on a printed plan that its automatically correct. And so we learn I guess. Will keep you all posted on the results.
« Reply #7 on: March 09, 2015, 12:49:21 PM »
The joys of CAD and laser cut ribs. At least you know they are correct - if the CAD drawing was anyway.
« Reply #8 on: March 09, 2015, 03:31:53 PM »
Go review my Legacy wing build!
Offline Balsa Butcher
  • High Desert Flier
« Reply #9 on: March 09, 2015, 05:16:47 PM »
All it takes is a long sanding bar to sand down the high spots, some glue and 1/16 balsa slivers to build up the low points, and lots of patience. Cover with cap strips, check for accuracy, repeat if necessary and move on. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Curare
« Reply #10 on: March 10, 2015, 12:17:49 AM »
or you could just do a foam core wing:D
Greg Kowalski
AUS 36694
« Reply #11 on: March 10, 2015, 05:52:12 PM »
not in this case - the ribs are not the right length either
  • High Desert Flier
« Reply #12 on: March 10, 2015, 06:10:42 PM »
Lengthen 'em then---CA glue and balsa scraps to the rescue, foam wing?, what?, and miss out on all this fun? That's one way. Actually, if faced with this many discrepancies I would make a good pattern out of plywood of the R-1 and end rib and carve/sand using the stack method.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Curare
« Reply #13 on: March 11, 2015, 06:35:08 PM »
BUT THATS TOO EASY!
There must be a way to complicate this more!
Greg Kowalski
AUS 36694
  • Dadda
« Reply #14 on: March 27, 2015, 02:42:11 PM »
Thank you all for the input. I have taken a bit of everyone's advice and managed to get the wings together relatively straight.  %^@
You guys have been a great help, and I have really enjoyed the humor. Thanks again. Will post some pics when it looks a tad more like a plane. n~
Offline Gerald Arana
« Reply #15 on: March 27, 2015, 06:14:56 PM »
Good one Pete! This is what I do too! y1
Jerry.
PS: Will I see you on April 18 TH?
