  • July 12, 2025, 08:37:58 PM
Author Topic: Engine exhaust footprint made easy!  (Read 2523 times)
« on: November 30, 2016, 08:09:14 AM »
I'm not sure if this is the right place to Post this tip?
I have this R/C Rossi I'm using for my Gee Bee R-3. The Build is at my "Sandbox." Anyone wanna play, c'mon over.
Anyway, I need a custom made tongue muffler for the engine. With that said I have to supply my muffler guy with the template, and I want to be exact.
Sooooooo, I did the sticky vinyl thing and trimmed the area with a #11 blade. A few times actually but I wasn't satisfied with any of the results.
I gave the task a bit of thought.
Clay would work for the imprint but I have no clay.
I decided to use my Stabilo and mark the edge of the exhaust flange. I used blue.
I then made a "stamp" with balsa which I pressed against the exhaust flange.
It didn't work.
Soooooooo, I then dampened the balsa with a bit of water and gave it a wipe with a rag to remove the excess water.
I again pressed the stamp against the exhaust flange and Presto Remco! it worked perfectly.
Here's the results.
Now I gotta get it in the mail.
Be interesting to see how others get this accomplished on engines muffler makers have no template for?
Charles
Online FLOYD CARTER
Re: Engine exhaust footprint made easy!
« Reply #1 on: November 30, 2016, 01:08:24 PM »
I have transfered parts to paper by "rubbing" with a soft pencil.  The same way people transfer Egyptian hieroglyphics from stone to paper.
« Reply #2 on: November 30, 2016, 01:18:45 PM »
Another option is to put a piece of parchment paper over the exhaust, and lightly rap on it with a plastic or soft hammer( a brass hammer would work too) This will cut the paper where the edges and holes are leaving you with a perfect template,,
Mechanics have used this method for decades to create gaskets,,
Offline Lauri Malila
« Reply #3 on: November 30, 2016, 02:33:47 PM »
That's a rather simple symmetrical shape with a couple of squares and 2 holes. What's wrong with taking the main measurements with a vernier and then drawing a simple technical drawing with desired dimensions?
Machinists do normally nothing with a small 1:1 picture. Anyway, to operate a milling machine it's good to know the actual dimensions.. L
« Reply #4 on: November 30, 2016, 04:35:56 PM »
Lauri,
The dimensions are on a piece of paper taking the trip with the balsa rubbing.
He will have both, just to be sure.
Mark,
I know about that taping but I don't have a brass hammer.
« Reply #5 on: November 30, 2016, 04:52:29 PM »
        All you need is a ruler and the ability to read it. Everything is symmetrical and can be laid out from a center datum line. You just need accurate dimensions for the holes centers and the opening size. Sometimes you make things more difficult trying to make them more simple.
« Reply #6 on: November 30, 2016, 06:02:59 PM »
My muffler guy asked for a template, which was the reason for my tracing.
I could have easily drawn it in CAD.
I mentioned he's getting measurements also.
