  • July 06, 2025, 12:00:49 AM
Author Topic: Engine crutch.  (Read 2455 times)
Offline Perry Rose
Engine crutch.
« on: January 11, 2018, 08:22:29 AM »
Am I the only one using 3/8 x 1/2  aluminum channel for the bearers instead of maple?
Offline Trevor Perry
Re: Engine crutch.
« Reply #1 on: January 11, 2018, 01:16:26 PM »
I haven’t read about anyone else doing it but I’ve just bought some 10mm (3/8) square aluminium bar for exactly that purpose. I’m planning to machine a channel and a taper in the rear half of the bar (a lot like the ones they use in the combat models). The plan for Charles Mackey’s Starlight states maple or magnesium for the bearers but magnesium seems to be unobtanium.
What thickness is your channel?
Sent from my iPad using Tapatalk
Offline Perry Rose
Re: Engine crutch.
« Reply #2 on: January 11, 2018, 02:44:23 PM »
The wall thickness is .062 so that 1/4 inch ply and balsa fill it nicely. I get it at hardware stores or Home Depot kinda stores.
Re: Engine crutch.
« Reply #3 on: January 12, 2018, 12:49:40 AM »
Ah, I think I see what you do now. So you are slipping the channel over the edge of the 1/4 sheet? I was thinking of basically using the al bar in virtually the same way you use a wooden bearer but mill it out as much as possible to reduce its weight.
Online Tim Wescott
Re: Engine crutch.
« Reply #4 on: January 12, 2018, 01:30:45 PM »
Hardware store aluminum is usually pretty soft stuff.  You may be disappointed.
Trevor: I've seen pictures here of motor beams made of aluminum, tapered and riddled with lightening holes in the back (although, I've never heard of lightening inside of an airplane, so I don't know why you want special holes for it to travel through is beyond me  ;) ).
Re: Engine crutch.
« Reply #5 on: January 12, 2018, 03:33:24 PM »
