CLICK HERE--><--CLICK HERE
Endgame IV Build
Started by Ken Culbertson, December 26, 2023, 02:29:46 PM
Previous topic - Next topic
0 Members and 2 Guests are viewing this topic.
Ken Culbertson
I thought I would ask Bob if he would move his workbench down here to align the nacelles but with at least four on his bench waiting I decided to try and fake it.  The motor is bolted into the nacelle.  In a perfect quad "P" I rebuilt the nose with the nacelles off. So much for the jig.  I suppose I could have made one that had a cutout for the nose but if I had sense enough to do that, I would have had sense enough to not do a second outside square with a 75oz plane flying 6.9 laps.  So here is what I did.  Leveled the plane on it's table mount.  Bolted the motor into the nacelle.  Slipped a 2' tight fitting CF tube over the motor shaft and put a line level on the tube.  Used the tube to hold the nacelle on while the epoxy dried.  I will post a video of the plane doing a slow roll on takeoff... LL~
I am finding out why insurance companies total cars that are just a little crashed!
Ken Culbertson
Time for the electronics.  I moved the ESC power switch to the top and 3" behind the prop arcs.  The old one was in the arc and scared me even though it never acted up.  Even with the wires shortened as much as possible you still get a blivit.
Ken Culbertson
#152
Timer came today. Climb & Dive Twin "Hourglass".  The size is slightly larger than the Fiorotti with a detachable start button and LED.  Fit like it belonged.  I am removing the timer power switch in the picture that was for the Fiorotti and moved the start button back taking it out of the prop arc.   That was a Quad "P" that so far had not bitten anyone.   n1
Ken Culbertson
#153
The Hourglass timer is installed and working.  Since I got no responses indicating otherwise that the Power Switch on the Jeti Pro 33 ESC could be shorted I proceeded to eliminate them.  It seems that the Hourglass timer uses ESC1 for timer power and ESC2 for landing gear power and they do not conflict like they do on a Fiorotti.  Powered it up today and it passed.  Now on to getting the ESC compatible!  It was good to find out that the Prop Strike on either prop will kill both motors at the same time.
This is fun!  Ken
Ken Culbertson
#154
Deleted
Ken Culbertson
Bad News - The Bluetooth App on the Android is no longer available.  There might be an alternate or a way of getting it outside of Google Play.  Aggh...........
DJohnson
I'm not familiar with the hourglass version. Is it a single timer that wires up to two ESCs?  I will be using a standard C&D timer with ZTW ESC on my Legacy.
Ken Culbertson
Quote from: DJohnson on February 03, 2026, 06:41:16 PM
It is the next evolution of the Climb and Dive.  Full of goodies. I am one of a few beta testing it.  What I am finding about technology is that your ability to understand it is inversely proportional to how long you have been using it!
Ken Culbertson
It finally flew today.  8 months and one funeral later it rose from the ashes.  Too much wind for a true test but indicators are that it is going to perform as well as before the crash.  I was wrong about the Tempest motors.  They performed beautifully with more than enough power.
As hard as I tried, I was not able to avoid adding weight.  The final product ready to fly with battery and line clips tickled the scale at 79oz and 80 if you didn't cheat.  The plane performed an expert pattern at 75oz if the weather was right (wind up to about 10).  At 80oz I am skeptical but 2 2820-840s can haul a lot of freight but 80os is not an acceptable weight for a PA regardless of how much power you have. It's new purpose in life will be as a test bed for timers and further development of the canard.  A new, slightly smaller (about 10%) version is in the procurement stage right now.  New Climb and Dive timer, twin 2315-880 all powered by a 5s 3000mah Li-ion battery.  I am still up in the air over the ESC.  The Spin's are over the top expensive.
DJohnson
Good that you got it in the air. Keep us updated on its pattern ability.
