  • May 23, 2024, 02:36:32 PM
Author Topic: Endgame IV Build  (Read 158653 times)
Endgame IV Build
« on: December 26, 2023, 02:29:46 PM »
I built Endgame as my last PA ship that I would fly till one of us died.  Well, it got murdered in a house fire, so I built Endgame II to take its place.  It flew OK but I have always wanted to try a canard, so I added one and II became Endgame III.  III is an unqualified success but I am still above ground and I have always wanted a twin PA.  I had one of those, I think it was Sterling, P-38's with two Fox 15's.  Ever try and get two Fox 15's to start at the same time?  It was a poor performer but the sound, ah the sound.  Well, after seeing Frank McMillen's twin which I commented on in the Endgame III thread it is official.  What appears to be the first twin canard is on the worktable.  There will be enough changes to give it a new name but it still has the same roots so it will be IV.  Aside from the twin setup it will have a 1" longer nose to give the canard more leverage and get it away from the props.  It will be totally in clean air so it should be even more effective.  One thing I noticed on III was that the large elevator/stab was too far back with the addition of the canard. The elevator became way too sensitive along with the logarithmic.   Great for corners but you have to fly it in-between them too!  So, I am moving it from 19 1/2 to 18 1/4.  I am switching airfoils from the Geo-Bolt to Geo-XL.  I used it on my Trifecta and the thinner wing seem to penetrate better and still have gobs of lift.  The last change I am making is going to inline.  I have no experience with this one so I am relying on those who have gone before to be right when they say that a twin electric should be inline.  I will post drawings/plans when they are finished for any and all to laugh at.  All suggestions will be appreciated.
Things that I have to decide on include the logarithmic.  III has a tendency to "snap" in a turn.  What I mean is that if I need to increase my turn rate in a round just a little it seems to overreact and "snap" making me miss the bottom.  I attribute this to having the logarithmic set to transition too soon probably from adding the canard.  I can't change the logarithmic to fix it on III without replacing it, which I may do, but I can correct in on IV.  The question becomes, do I need a logarithmic at all with a canard?  III will turn as tight a corner as I want to fly and keep the wing in one piece.  I have yet to stall it in a turn or attempt a "bang" corner.  I have done maneuvers with corners so tight as to be annoying to those watching - without any stall.  Never thought that was possible.
I have another question but I will make it in a separate post, so my ramblings don't clog up Sparky's drive.
Re: Endgame IV Build
« Reply #1 on: December 26, 2023, 02:34:02 PM »
This is the question.  Do all of the horn, pushrod configurations have the same effect.  Ignore the logarithmic, it is only there because it reverses the direction of the elevator pushrod.  I really need to use #2.  All angles are 90 degrees to the pushrod.
« Last Edit: December 27, 2023, 09:18:48 AM by Ken Culbertson »
« Reply #2 on: December 26, 2023, 06:57:36 PM »
To me I built the Sarpolis canard to prove to prove to myself and others that they will fly and do a pattern.  I have witnesses to that when the LA 40 is set right.   So I constructed my version of a Ringmaster canard without the rear moving surface  The canard has no control of the plane until it gets moving through the air.  I had an LA 25 for power.  Had to extend the gear as far forward as I could get it so the plane would not nose over.  Once it got moving and control of the canard started it flew better than I fly.  I learned that is why the Sarpolis canard had the rear moving surface.  It was to keep the nose up until some speed was obtained.   Yes it was strange to look at while flying.   When I get to rebuilding the Ringmaster canard it will get a moving tail surface.  Works like an elevator.
By the way searched for canards on the internet.  A lot of good reading and why people who have built the Bert Rutan canards had to learn a few things.   They don't handle like a Cessna or Piper Cub.   D>K
Online Lauri Malila
« Reply #3 on: December 26, 2023, 11:27:42 PM »
This is the question.  Do all of the horn, pushrod configurations have the same effect.  I really need to use #2.  All angles are 90 degrees.
 Number 1 would be interesting to watch as flaps turn to wrong direction compared to elevator. L
« Reply #4 on: December 27, 2023, 07:40:43 AM »
That was what sketching things in a hurry will do.  I was trying to illustrate the direction with a logarithmic and left that tiny bit of information out.  I will revise the illustration!  Thanks for pointing that out.  What about the other two?
« Reply #5 on: January 09, 2024, 04:32:44 PM »
Construction underway.  First order of business is always the stab with me.  Then I make the fuselage.  Last, the wing.  Just me.  I like cockpit detail so I make the fuselage with a removable cockpit module so that I can work on it whenever I get the urge then glue it in at the last minute, of make it a hatch.
Some pictures. Stab is using pocket hinges from Mark Wood's skunkworks.  They are recessed 1/8" into the TE.  The TE is 1/2" thick and airfoiled from a .025 radius LE to a 5/16" TE.  1/32" thicker than the elevator Top and Bottom.  Used wire to protect the LE.  The elevator is 1/4" tapered to 1/8" with full span 1/4" fences on the TE.
Fuselage will have "X" bracing in place of formers.  Sides, top, bottom and center.  Remember how solid those old Comet  kits were.  Without all that pounding from an IC I think this construction shows promise.
More to come.
« Reply #6 on: January 10, 2024, 04:51:59 PM »
Got the aft fuselage framed.  The 1 1/6 sides are fine.  The twist capability is next to nil and I don't even have the bottom framing.  That goes on after the pushrod is in.  53 grams including the CF doublers in the unframed nose.  It is going to be a twin so all that will go in the nose is the battery and timer and perhaps the ESC's.  I haven't decided if I am putting them in nose or the wing.
For what it is worth.  That .3mm CF Sheet is fantastic.  It cuts with scissors and is stronger and lighter than plywoood.  The wing LE is reinforced for the pull test.  I am going to use .5mm for doublers in the motor nacelles.
« Reply #7 on: January 19, 2024, 03:02:13 PM »
One step closer.  I have molded the top aft fuselage. 59 grams as it sits.  Seems a bit light since it only weight 53 grams before the top shell.  I will never use blocks again, that is for sure!  Still trying to figure out where to put the ESC's.  In the center with three long motor wires and short battery wires or in the nacelles with short motor wires and long battery leads.
I am using BadAss 2320-850 motors on a 2800mah 6s battery,  If I cheat and use 13gauge wire I should be OK either way.  I have a question on the long motor wires if anybody knows.  Should I twist them so that there is not a long stretch with them straight?  I suspect it doesn't matter.
Offline Wolfgang Nieuwkamp
« Reply #8 on: January 20, 2024, 03:03:14 PM »
Nice project!! An ESC does not like twisted motor wires. I would use the motor wires as supplied.
Wolfgang
« Reply #9 on: January 20, 2024, 04:01:42 PM »
Wolfgang
Thanks for following the thread.  You were the inspiration for my Canard.  IMHO it has been a huge success.   I hope you have had a chance to see it in action.  If not here is a link.
This was only the 4th or 5th flight on the plane so it is still *way* out of trim.  The overall pattern is still a bit rough but watch the corners!  These are about 1/2 the tightest it will turn.  It will do a 90 degree turn in about 2 plane lengths - scarry.  Unfortunately, it has a stock Geo-Bolt wing and I don't think at 68oz, the center section is strong enough to take that kind of corner over time. The only design issue that I encountered was a tendency to self-tighten in the rounds.  I got that trimmed out later by adjusting the flap elevator ratios.  The III has a logarithmic flap horn and it was allowing too much elevator in the rounds.  I am not going to use one in IV.  Don't need it with the canard.
I am going to stiffen the center section on the new one.  Partly because it is weak on the Geo-XL I am using in this build but also because it will be a twin and will need the extra support.
« Last Edit: January 20, 2024, 10:43:37 PM by Ken Culbertson »
Offline Steve Glass
« Reply #10 on: January 21, 2024, 11:33:00 AM »
I think that I read somewhere that there is a technical reason to always use short battery wires and long motor wires?  Rather than vice versa.
« Reply #11 on: January 21, 2024, 11:43:20 AM »
You are right.  I got that answered in another thread.  Thanks!
« Reply #12 on: January 23, 2024, 10:54:39 AM »
My Phoenix Edge ESC´s work with 50 cm battery leads, Maybe cheaper ESC´s need shorter battery leads, because of their smaller input capacitor.
On the top horizontal of the square eights I noticed sudden RPM increase. Do you use the Circuit Flyer timer? That uses a gyro to influence the RPM when turning, I suppose.
Maybe you should test  my new timer, which does not use the gyro, but only keeps the line pull constant....
Best regards,
Wolfgang
« Reply #13 on: January 23, 2024, 02:21:41 PM »
Best regards,
Wolfgang
What is in that plane is a BadAss 3520-750, A Jeti Spin 66 and a Fiorotti timer.  You are correct, there is a small boost there when the g-force of the Fiorotti timer kicks in.  It is actually a signal to me that I made the maneuver big enough.  I tend to fly small, and I would not get the boost under 45.  It is really noticeable in the top half of the V8 and is also a signal that I have my intersection at 45.  It stays on for all of the overhead 8 unless I dip down too much.  It is a bit tricky to get set right and I have mine set higher than most because of the really strange winds we get over 45 degrees.  You can see in the background of the video a train track on a levy. When the wind is from anywhere near over those tracks, we get serious turbulence over 45.   Having the extra RPM's helps.  I guess my transition to electric is complete since I no longer pay any attention to the sound the motor is putting out in flight.  ::)
It is going to be interesting to see how the Canard responds in clean air.  Both props on the twin will be behind it.
« Reply #14 on: January 23, 2024, 04:21:49 PM »
What better use can there be for a cheap Chinese spinner than a radar dome doubling as a nose weight box!  Nose is shaping up nicely.  I am having to learn a new skill set to build with everything molded.  Al would be proud!
Tomorrow I build the Canard drive.  All that stuff needs to be in place before I can finish up the nose.  I am itching to start on the cockpit interior.  On the original I used wheel collars glued to the Canard to allow it to slide off of a 5mm carbon fiber rod and therefore be adjustable.  It worked great for about 2 adjustments then the CF rod started slipping.  So that was replaced with an arrow shaft that was fixed.  Both were anchored to the wing with ball bearings Epoxied to the fuselage.  My dream of having an extra surface to trim wings level went "poof".
Offline Steve Dwyer
« Reply #15 on: January 24, 2024, 08:37:17 AM »
Ken, Burt Rutan would be proud of you.
« Reply #16 on: January 30, 2024, 07:34:47 PM »
I am about to order the ESC's and motors from Russel at Okie.  I will be using 2 BadAss 2320-820's and I hope the Jeti Spin 33 ESC.  Problem is that the Spin 33 is only rated for a 5s battery but it is rated for 26 volts which is over 6s.  I have plenty of 5s 2800 batteries so that would be a good thing but I question if the 5s has enough head room for 2 motors.  I am having fun composing this plane.  I like to do things in random order.  Lots of subassemblies.  Right now I am building out the nose.  I will make the entire front top removable so that I can work on it and glue it on after the wing is installed.  Next step will be the bottom hatch.  That will be the tough one.  Need a mount for the nose gear.  First trike I have built since the 60's.
« Reply #17 on: February 15, 2024, 06:46:47 PM »
Progress is slow when you are making the cool stuff.  Never built using all 1/16.  It is scary but the end result is just as stiff and so light.  I am finding that .3mm CF Sheet makes a wonderful substitute for plywood and bass.  First it is lighter and second it makes you fingers itch for days after sanding it.  Here are some nose and fuselage shots and my combination nose wheel and battery box.  Matt - The Nose wheel is adjustable.
Added 1/2 of the Canard.  Composing this nose is fun.  Everything is a first!  Camera sure does distort things.  The tips on the Canard are swept back at 15 degrees.  Looks opposite in the pix.
« Last Edit: February 16, 2024, 04:39:39 PM by Ken Culbertson »
« Reply #18 on: February 25, 2024, 09:49:31 PM »
The most difficult thing in making a new plane is making the second elevator, flap, or in my case canard.  They do look better with two.  The motors, esc and timer came today.  Haven't laid it all out yet.  I am still trying to place the ESC's where they will cool properly and not be a pain to service.  One question I have not answered to my satisfaction is whether they need to be separated and if so how far.  I will be using a 5s 2800 battery so I can get away with 18 gauge wire which matters since there will be 9' of it from the ESC to the motors!  (3@motor x 18").  "Bing" tells me that the wire will weigh 10 ounces - OUCH!.   I am still shooting for a "start the timer" weight under 70 oz.  I made a decision to go with a Geo-XL wing vs the Geo-Bolt I used on II & III because folks who have been at the electric game longer than I have convinced me that I didn't need the thickness of the GBolt. I sure hope they are right!
Some Pix of the "fun" stuff I have been working on.  I have found that if I build the wing first it wants to fly and I do a hurry up on the fuselage and stab.  So, I save the wing for last.
The adjustable logarithmic is in the works.  I will skip the cam rudder.  With the separate settings in the Fiorotti timer for each motor I will not have any use for it.  The one fear I have with a twin is an inboard only motor failure.  Have any of you adventurous types ever tried flying on just the outboard?
 One of the things I had to do with III was restrict the bellcrank to 60 degrees to keep it out of the way of the canard pushrod.  I am going to put in a 5" bellcrank to give me back some of the leadout movement I lost plus the extra leverage doesn't hurt.  The 5" will also require some very smooth leadout guides.
« Last Edit: February 25, 2024, 10:08:12 PM by Ken Culbertson »
« Reply #19 on: February 27, 2024, 06:30:58 PM »
The new toys came in today from Okie.  Spin33 Esc's, Badass 2320-820 motors (they are so cute), and a Fiorotti New Timer.  I am still planning to put the ESC's in the fuselage with long motor wires.  They are 16 gauge so it won't be too heavy.  The Spin documentation says to not extend the motor wires which is opposite of what I hear from the forum.  Props will start with 10 x 5 BadAss two blades.
« Last Edit: March 03, 2024, 08:24:22 PM by Ken Culbertson »
« Reply #20 on: March 01, 2024, 07:23:52 PM »
Started work on the nacelles.  Got the props in pair of BadAxx 10 x 5's opposite rotation.  That little motor sure is cute.  I don't see how only two of these little things can power a 65oz plane but those who know far more than I do say the will. y1
« Reply #21 on: March 08, 2024, 09:59:56 PM »
Nacelles done.  My style is more like composing than building so making two of anything gets dicey.  At least they came out looking similar!  Anybody seen my other spinner?  20grams each w/o motors at this point.  Once they are fitted to the wing I will glass them.  Construction is 100% Balsa except for the CF reinforced engine mount.  I have decided to put the ESC's in the fuselage.  Motor wires will run through a smoothie straw built into the wing.
« Reply #22 on: March 13, 2024, 12:00:02 PM »
Looks like the bots have lightened up.  Only 70000+ reads.  Here is the proposed power train.  I have never wired a twin so if anything anybody sees that looks strange please post your concerns.  Only one I have is placement of the ESC's.  Some electronic components do not like to be next to each other.  I have no clue if this is true for an ESC.  Probably not.  The rest is just making up the wiring so that you can get it out later if necessary.  I do have a question on the ON/Off switch.  Can one switch serve both ESC's or should I have 2.  I assume one is OK.
One thing that saddens me.  I have always used the 2nd ESC port on the Fiorotti timer as a programming port that I route to a receptacle on the side of the plane.  I don't have to unhook anything, just plug in the Jeti-box to change settings on the timer.   Now I have to plan on an easy to remove hatch for programming. Boo!
Soon as I have the whole thing wired I am going to bench run to see what it does.  Being able to run the motors without a prop - priceless.
Oh, Plan "B" is to put the ESC's on edge to separate them more if necessary.  I want to keep them side by side in the center to keep the wires to each motor the same length.
« Reply #23 on: March 16, 2024, 12:04:30 AM »
Lots of changes to the electronics wiring thanks to some of our more experienced twin folks.  Got the full shape of the fuselage finally with the control horn access hatch finished and most of the nose hatch.  The 1st 12" of the bottom is a hatch giving me access to all of the goodies.   I think that the nose looks a bit too much like a Sturgeon.  I think I will reshape it more like a F-86.  Covering is going to be Polyspan and laminating film. Can't paint much in the office.  I really would like to do this in Dope, but it isn't going to happen.
Almost time to build the wing.  Soon as the nose is done, the electronics positioned, the stab & rudder mounted.  Wing is always last.
ken
« Reply #24 on: March 20, 2024, 06:57:35 AM »
Composing an airplane can cause you to say things that are not acceptable in polite society.
Today was wiring day and I was able to get everything crammed into the nose, but the only way to fit the timer and still have access was to turn it with the pins pointing straight down.  You can't bury the thing because you have to be able to unhook the timer to program the ESC's.  With the six motor wires going into the wing the ESC has to be turned around and the leads to the battery box and the "Y" splitters have to go in the front where there is no room then there is that darn arming plug.  Has to go in front of the positive splitter which meant another 6" of 14g wire.  So instead of having it tucked neatly near the wing joint it will stick out like a woodpecker under the canopy.  Either that or 14" of wire.  Maybe I will shape the plug to look like an air-air refueling port.   I had to use more bullets than a John Wick movie just so that I could take it apart later.  With the wiring all in place it was time to check the top and bottom "blocks" to see what it looked like enclosed.  Timer on the bottom, arming plug on the top didn't clear, not even close.  So we now have a fake cannon blister to cover the timer leads and the pilot's left console is now 1/4" up.  It was either that or amputate his left arm.  Having the Canard's pushrod run smack down the center of the nose creates some serious design issues!  I guess that is the price you pay for designing your own.
Reshaped the nose more like a F-86D.  Not exact but close.  All of the pieces are "finished" now except the wing.  34.89 oz with everything, motors, battery, esc's, timer.  All that is left is the rudder, wing and wheels.  I guess I can pull that off with about 15oz which puts me at 50oz.  Finish will be a first for me.  SLC over polyspan with a military paint scheme of some sort.  I am optimistic that I can keep it under 60 which will be 10oz lighter that the single motor Endgame III.
If you are a "tinkerer" like I am you always come up with a better way just about the time you finish a component and that is why we never stop building and rebuilding even when we don't need any more planes!
« Reply #25 on: March 20, 2024, 04:50:52 PM »
Rule 23:  If you are not satisfied with the way things are coming out, don't fix it now.  Wait till tomorrow so that you can worry about it all night.  I had hooked up the battery to the splitters using a T-60.  It really didn't fit and made the battery wires too short.  So, after several hours of rationalizing how it would be OK, I went home.  Today I took the wire cutters to the T-60 before I had a chance to back out.  Replaced with bullets and everything fits.  After all a T-60 is just two bullets in a pretty yellow wrapper.  Raised the console so that the arming plug fits and finished the fake gun port to cover the timer.  All that is left for the wiring is to shorten the timer cables.  One thing I have noticed.  Using Carbon Fiber in places you need to sand sure does make the plane look dirty!
« Reply #26 on: March 23, 2024, 03:25:58 AM »
Everything excellent! Only the leading edge of the canard looks a little too sharp to me.
Wolfgang
« Reply #27 on: March 23, 2024, 09:10:11 AM »
Wolfgang
Interesting that you mentioned that.  Endgame III had a total of 4 Canards before I settled on this one.  1 & 2 had 1/16" radius LE and were 1/2" thick at the high point of a 3" chord and 5" span(each).  They were independently adjustable, theory being that I could use them for trim.  On 3,  I extended the chord to 4" and span by 1" on each side and thinned them to 3/8" fixed.  Having them adjustable didn't help anything.  On 4 I added another 1/2" to the span and sharpened the LE to a 1/32" radius.  This is what I am flying now on III and I copied it for the twin.  The canards in the picture are unfinished.  I have a CF strip imbedded in the LE which will be sanded to the 1/32 radius.  I use .025 wire for the LE of the stab which is quite sharp but not 'razor' like some use.  I studied a lot of the jet canards and most had sharp LE's.  I am in uncharted waters with this one since it will be in front of the props in clean air.  I won't know how it will react till I fly it, butterfly's are being put on standby!
I have had to dial back the corners on Endgame III.  It has a stock geo-bolt wing which is not as strong in the center section as I would like for the turns it is capable of.  I moved the CG forward 1" and changed the ratios on the controls to 20-20-30 from 15-30-40 maximum deflection.  That calmed it down enough that I don't fear folding the wing anymore.  Tight corners are creeping back into the AMA pattern, but they are still not anything like you fly in F2B.  The new ship will have a wing capable of an 8' corner without breaking.  One thing I do not want compromised is the ease that I can do sharp turns with less line tension.  The canard takes so much pressure off of the flaps that I no longer worry about making the turns in the hourglass and overhead 8 with the reduced line tension. Even in a strong wind I get the deflection necessary to prevent sagging with very little line tension.  Being able to fly an hourglass with the last corner as tight as the first is worth the effort all by itself.
Cheers - Ken
« Reply #28 on: March 23, 2024, 09:21:17 AM »
Subsonic and in clean air I would use a NACA 0009  :-)
Wolfgang
« Reply #29 on: March 23, 2024, 10:26:48 AM »
Wolfgang
That is Pretty close to what I have.  I have rarely, since my FF days used the NACA numbers.  I use the "That Looks Good" table instead.  My LE is a bit sharper but negotiable.  I will round the LE to a 1/16 radius.  I just love sanding CF.  Fingers itch for weeks even if I wear gloves!
« Reply #30 on: March 28, 2024, 06:52:40 AM »
Thought it would be worth posting what this beast will look like.  I drew this up do that I could plan panel lines.  I settled on SLC over polyspan for the finish base after a successful test on the canards.  Everything else on this plane is a first for me, why not the finish!
« Reply #31 on: March 29, 2024, 07:11:54 PM »
I think I found out why the high count.  I just did a search for Endgame IV on Bing.  My thread was in the top 50 out of 800,000 returns.  Endgame 4 is a popular computer game.  The AI probably sees it as the same thing.  Up to 90,000 now.  I hope they all don't build a stabalator canard!  LL~
« Reply #32 on: April 01, 2024, 10:47:46 PM »
Made the wing spars today and cut the right wing ribs. Those Warren Truss ribs sure are long!  It's my first.  Had to make a stripper to cut the spars.  2@ 1/8" x 1/4" strips making a sandwich with a .3mm CF strip of carbon fiber plate in the center (no mayonnaise).  What is so cool about the carbon fiber plate is that you can cut it accurately with scissors. I figured with the motors on the wing and tricycle landing gear, having a beefed-up spar was not going to hurt.
I will ask it here just for grins since only bots seem to be reading this.  How does one mount wing gear in a Warren Truss wing?
« Reply #33 on: April 03, 2024, 04:44:26 PM »
My first Lost Foam Warren Truss wing is out of the jig!  Have to complement Bob Hunt on making wing building easy.  Found a good use for Wynn Paul's books when I am not reading them.  The hard part was locating a place to put wing gear for a tricycle setup in that wing.  Think I found it.  The nacelles are going to attach on one of the two half rib sets so I am going to make a .5mm carbon fiber mount for the gear there.  5" bellcrank and flap mechanism should be here next week.  Once the wing is built I go into "wanna fly it" mode! LL~
« Reply #34 on: April 12, 2024, 05:22:33 PM »
Control box mounted and pushrods made up.  So far so good.  Elevator gives me 40 degrees in both directions with equal movement of the logarithmic horn.  Next up will be the inboard wing.
« Reply #35 on: April 15, 2024, 04:41:14 PM »
Controls tested and set aside till I get the wing installed.  The 5" bellcrank worked perfectly.  I have it set to give me full elevator with 1 3/4" of leadout travel which matches my other planes.  Flaps and Canard max out at 20 degrees, elevator at 35. All are adjustable.  Finished covering the stab and roughed in the recessed flap insert.  Normally it would be a 1/32" molded insert but I found that smoothie straws are the perfect size and lighter that the balsa.
Online Don Jenkins
« Reply #36 on: April 16, 2024, 06:21:40 AM »
...and much more colorful!  Nicely done.
Don
« Reply #37 on: April 24, 2024, 05:49:52 PM »
One more subassembly nearing ready for the fuselage.  The 5" bellcrank saves a complete full rib of shear web over the 4".  I will be able to run CF out to the Nacelles and not hit the controls.  I am using .3mm Carbon Fiber over the 1/16" balsa for the webbing.  The Geo-XL wing center section was not designed to handle the weight of the motors and wing gear so I am reinforcing it using a lot of thin CF.
« Reply #38 on: April 26, 2024, 06:28:56 PM »
 Finally got he wing framed.  Bellcrank and landing gear Monday.  Thought it was time to put it together for a test fit.  Pretty close, needs some work on the nacelles.  Right about now I am cursing Bob for getting me into this but seeing it together has rejuvenated me!
« Reply #39 on: April 29, 2024, 01:23:04 PM »
After reading a lot and listening to a lot of recommendations I have decided, and installed, a DPST switch to turn on both ESC's from one switch.  I got some telling me to wire both switches to on and just use the Arming Plug, powering one from the switch and leaving the other one open, to having a switch for both.  I liked the last one so it now has both ESC powered and the power lead on the 2nd BEC cut.  I don't like the idea of the arming plug powering up the ESCs.  I always insert it with the switches off.
« Reply #40 on: April 30, 2024, 11:58:40 PM »
Wing is getting fitted out.  Center spar reinforcement assembled.  Consists of two laminations of .03 CF Plate over a 1/8" balsa core.  This is my new plywood.  Considerably stronger Bellcrenk pivot wire (1/8") goes through the center.  Plumbing for the motor power cables added and cut the openings for the canard pushrod.  Landing gear mounts next.  Todays progress was interrupted by the wall mounted hook to hang Endgame III broke and THUD she fell three feet.  Saved by the collett.  It slipped and let the spinner absorb the shock.  Aside from a broken battery limit - no damage!
« Reply #41 on: May 08, 2024, 07:47:55 PM »
Mounted the flap control box and bellcrank.  Works great.  Absolutely no binding anywhere.  Now I have a question.  I hesitate to ask it here because I don't think anybody reads the build threads if they are in the building forum but here goes anyway.  I have to have trike gear for the twin and I need to place the rear wheels at about 1" behind the CG.  I have no clue where the CG should go on a GEO-XL airfoil.  I know a million other factors play into the exact position but if I can at least get a ballpark I can bend some wire.
Offline Larry Renger
« Reply #42 on: May 09, 2024, 08:17:09 AM »
Don’t forget, the canard will require moving the CG forward of a normal configuration.
Make a simple sheet scaled down model and tie some string to the wingtip. Swing it around to get some speed over the surfaces.
Move the CG aft till it flops around and you have discovered the limits. I would guess that 10% chord aft of that would be a good starting place.
Actually, my guess is that airfoil has little to do with stability on a symmetrical airfoil wing. Tail and canard area/moments are the controlling factors. 🤠
« Reply #43 on: May 10, 2024, 06:46:02 AM »
Endgame III eventually had the CG 3/4" forward of it's non-canard but same airframe Endgame II (is there no end to Endgames?  Maybe I need a new name!)  With the twin canard I am so far out in uncharted waters I can't see the shore anymore.  How does double the airflow over the center of the wings with the canard in clean air affect lift is a big one.  As far as I can tell, there is not another example of a "stabilator" canard that I can pester the designer for ideas.  Had I thought about it more I probably should have gone to a "stabilator" tail as well.  Ball links and fiber pushrods make them possible.  I tried one many years ago but slop in the controls made it difficult to track properly (nice corners).
My only concern with the CG at this point is where to mount the wing wheels.  Two far forward and takeoff and landing get funky, two far aft and I need nose weight.  The main spar on the Geo-XL wing (Bob Hunt's Lost Foam Version) appears to be close to where I would put the CG for the initial flight.  I will put the main gear 1" behind that and if she doesn't fall on her butt - fly it.  Two laps and a loop will tell me where the CG needs to be for trimming.
Thanks for the reply - Ken
« Reply #44 on: May 10, 2024, 07:37:25 AM »
Back to the build.  Assembled the main components and resized the pushrods.  Found that the Flap gizmo was not giving me enough elevator so I shortened the distance between the levers and now I get 40 degrees with 1 1/2" leadout movement.  40 degrees on a canard is huge so I should be OK even though I had intended my stops to be at 1 1/4" movement each direction.  Controls are so loose and slop free with the new ball links Bob Hunt suggested.
I did have to re-do the pushrods to have more thread exposed.  These links have about a 1/8" recess before the threads make contact - better but if you have trimmed for the DuBro's you are too short!
Added 5/16" cap strips and wingtips glued on (they fit, imagine that).  As soon as I get the gear mounts done the wing gets mounted and I can finally start beefing up the aft wing/fuselage joint and covering up all the false starts that come from composing an airplane vs building from plans  HB~>
« Reply #45 on: May 11, 2024, 07:55:17 AM »
Need to test the controls with all parts installed so I am taking a side trip to build the flaps.  I am using the European / Sparkey style flap hinges except I am making them removable via a pull wire.  With this type of hinge it is even more important that the flap horns are exactly on the same line as the hinge pivots.  For that reason they are mounted using two hinge posts drilled out to match the brass bushings on both sides.  The pictures show the construction of the flap LE with the wire tunnel.  I use .025 wire for the hinge pivot and each hinge is accompanied by two 1/16" aluminum bushings, one on each side and one in the center of the post. i use a 3/32" drill to bevel the inside of the bushing openings so that there are no flats for the hinge wire to catch on and I sharpen the wire end to a dull "pencil point" shape so that it can be inserted at the wingtip and pass without obstruction through all 5 hinges.  In forming this CA glue is not your friend.  I swear that stuff has tracking capabilities and is trained to find a path to whatever place you do not want it to go or your finger.  Bottom line, I wasted three bushings and 6" of wire just on the outboard flap.  Once the bushings are in, alligned and the glue is cured, glue the top 1/8" strip on using slow cure CA, (it does not have trackers). Now run the wire in and out enough times that you are comfortable it will come out after you have applied that 20 point finish. (in my case 15 point) and add a 5/16" .3mm Carbon Fiber cap to the back of the LE.  Now you can cut out the slots for the hinges without breaking things too much.
5/16" cap strips added to the wing and it is ready to install as soon as the controls with flaps are tested.
This is the 1st plane I have built since the 80's that will not have a CAM rudder.  I have been assured that the rpm differential capability of the new Fiorotti timer will make it unnecessary.  With IC I would be at the "screw the finish - let's go fly it" stage of a very long build but, with electric I don't even schedule the finish till after I have flown it!  Life is good (as long as I can still build and fly!)
« Last Edit: May 12, 2024, 01:15:30 PM by Ken Culbertson »
« Reply #46 on: May 15, 2024, 10:23:24 PM »
Made a new set of flap horns when I found that the dogleg ones from Russel interfered with the logarithmic.  The good part is that the logarithmic tray mounts to the back of the wing so that every part of the control system is accessible for fine tuning.  Most of today was spend making the new horns after wasting half of the day trying to make the old ones work.  Most of tomorrow will be spent recovering from the brain fart of the century.  When I decoded to make Endgame IV I took my "plans" from Endgame III and traced them.   One of the changes I made was to put the horn for the canard on the outboard inner side of the fuselage pointing down so that it would be accessible through the nose hatch and I could use a standard horn.  For this I had to attach the pushrod to the opposite side of the bellcrank from the flap pushrod.  After some discussions with Bob Hunt about twins I decided to jump the shark and go full inline.   So I lowered the canard to the centerline but now the horn was too long to be on the bottom.  The canard doesn't move much.  I have about 3/4" up and down at the TE of the canard.  That equates to about 10 degrees.  I get that with the bellcrank hole at 7/16" and the "horn" for the canard at 1 1/8".  It is adjustable to give me as much as 20 degrees deflection if I want but I doubt I will.
 No biggie, plenty of room on the top.  That was three months ago.  Today, after making the new flap horns, I hook it all up and marvel at how free and smooth all it is. (Thanks Bob, those ball links are fantastic).  Then it hit me, when the flaps went down, the Canard went up.  Sh.......t. The Canard pushrod was on the wrong side.  The main spar cutouts are cleared for the pushrod to be on the outside of the pivot.  Now they are on the inside. One more hole in the main spar.  Thankfully I used CF webbing out to the nacelles.  Ok, the good news is that the canard pushrod is now straight down the nose center.  The bad news is that the tunnel for it is still angled for the outboard position. and the Cockpit interior is built to hide that tunnel.
The beauty of the hobby to me is that I get just as much enjoyment from building as I do flying and I love to tinker with things.
« Reply #47 on: May 19, 2024, 11:33:23 PM »
Built the TE flap tunnel and mounted the first flap.  When I use imbedded flaps, I use a technique that insures a "perfect" fit.  First I sand the flap to have a smooth 1/4" radius on the LE.  Next, using a sandpaper covered dowel I sand the radius into the wing TE.  Next, I mold a piece of 1/32 around a 1/4" dowel so that it is just over 1/2 the diameter and set it aside while I bush the barrel hinges.  I use 1/16" aluminum or brass tubing for the bushings.  Drill the holes in the hinges and push the tubing through the hole to about 1/8" .  This is to keep glue out of the hinge.  Run a bead of slow cure around both sides and work the tubing back and forth to get as much flue as you can in the hinge hole.  When it sets, cut off the excess with a razor saw.  I file the hinges flat then I take a 1/16" sharp drill in a finger drill and bevel the insides of the bushing just like I did on the guide.  With the wire sharpened and all of the guides and bushings beveled, the wire will slide in and out effortlessly till you get tired of taking the flap off.
Put all of the hinges onto the flap using the hinge wire then take the molded TE and cut out the little squares for the hinges.  Wet some 1/32 strips to act as spacers for mounting the flap.  The spacers go one each between the hinges the flap LE.  With the molded TE up against the flap with the spacers between them and the hinge legs through the LE, start the hinges i their holes them push the flap up against the TE as hard as you can.  This will seat the hinges in their blocks and form the gap between the wing and flap in the tunnel.  Now, with pressure still on the flap glue the tunnel to the wing TE by running a bead of thin CA  along the seams.   Pull the wire out glue the hinge.  I poke a tiny hole in the sheeting then stick a glue tube tip into the hole and bathe it with CA.
« Last Edit: May 20, 2024, 06:27:06 AM by Ken Culbertson »
Offline Mark wood
« Reply #48 on: May 20, 2024, 09:41:26 AM »
The general rule of thumb for trike gear is that the mains axle be placed at an angle 15 degrees behind the CG.
BTW, those is some nice looking control system parts....
Life is good AMA 1488
