  • June 20, 2025, 04:30:41 AM
Author Topic: Lucky Boxes II  (Read 3350 times)
Lucky Boxes II
« on: August 28, 2010, 06:16:24 PM »
I tried o post on the one I found about the Lucky Boxes but was told by comuptor it was too old.  The King Sweep has qute a bit of sweep back on the trailing edge.  What I need to know is if I make the flap horn bends at the end of the flaps.  The horn is being installed ona peice of wood so it it will be straight across at the center section of the wing.  Someone stated using Phenolic material for the top and bottome surfaces.  What I can't remember is what is the angle of the flap horn arms at the flaps.  Or do I leave them going 90 degrees to the hinge point of the horn?  Spent today getting the bellcrank partially mounted.  Didn't think about how much bigger than the Sweet Sweep this is going to be.   H^^
Offline Leester
Re: Lucky Boxes II
« Reply #1 on: August 28, 2010, 06:37:19 PM »
Doc, I'm pretty sure the horn arms are suppose to be 90 degrees to the trailing edge of the wing.
Leester
ama 830538
Re: Lucky Boxes II
« Reply #2 on: August 29, 2010, 08:38:49 PM »
Hi Doc-
Bend the horns 90 degrees the same as any normal model as that is the usual practice. However, the horns could be at 90 degrees to the trailing edge just as well. The amount the end of the horn articulates as the flaps move is the same either way. 90 is just easier. I use 1/8 x1/4 brass tube for lucky boxes, works great with 3/32 horn wire. Just be sure the horn tips are real close to the outboard edge of the box when the flaps are at neutral as the ends will move toward the inboard edge as the flaps move up and down. I am not real thrilled about epoxying fiberglass sheet for lucky boxes as the epoxy doesn't adhere to the slick surface all that well.
Don
Re: Lucky Boxes II
« Reply #3 on: August 31, 2010, 10:31:58 AM »
G-10 epoxy board material (sometimes called FR-4) works well for lucky boxes, and a lot of other stuff.  The secret is to rough up the surface of the epoxy-glass board and use JB Weld.
Offline Allan Perret
  • Proverbs
Re: Lucky Boxes II
« Reply #4 on: August 31, 2010, 11:50:51 AM »
Hey Floyd:  What you are describing is more commonly known as phenolic or micarta.  That is tought stuff, I use it for motor mount pads.  I have used it for horn pockets, but have changed to spruce or bass because it is much easier to sand and shape into flap tapered cross section.
Allan Perret
AMA 302406
Slidell, Louisiana
  • Proverbs
Re: Lucky Boxes II
« Reply #5 on: August 31, 2010, 11:52:51 AM »
Neat idea Don.  Do they also have a rectangle tube that will accept 1/8 horn wire ?
Allan Perret
AMA 302406
Slidell, Louisiana
Re: Lucky Boxes II
« Reply #6 on: August 31, 2010, 12:21:57 PM »
I hate to disagree, but FR-4 is, indeed, an epoxy-glass laminate.  You can get phenolic circuit board material.  It's often used in really cheap consumer electronics because it's -- well -- cheap.  But epoxy-glass is quite common, and is to be found anywhere that the circuit board quality can make or break the product (I doubt that you'll find a phenolic circuit board inside of a PC, for instance).  Phenolic is used in things like cheap radios and electronic alarm clocks; it's mostly restricted to far east manufacture these days.  FR-4 is what you'll usually find as surplus copper-clad board in the US and probably Europe.
I hear you about your material choice -- I'm currently making my very first pair of lucky boxes for a V-tail; I'm using FR-4 because that's what I have around and I know that I won't have to worry about strength.  But I'm not looking forward to getting any exposed corners to look good.
Re: Lucky Boxes II
« Reply #7 on: August 31, 2010, 12:54:24 PM »
I don't know if K & S makes a "square" tube that size. Go to your local Ace hardware store with a 1/8 drill bit and check the rack of K & S tubing. I guess it would be 5/32 x 9/32.
Don
  • Proverbs
Re: Lucky Boxes II
« Reply #8 on: August 31, 2010, 03:12:57 PM »
My source for phenolic is McMaster Carr.  In there catalog they list G10 / FR4 as one of several grades of phenolic.  They also call it Garolite.
Allan Perret
AMA 302406
Slidell, Louisiana
Re: Lucky Boxes II
« Reply #9 on: August 31, 2010, 03:18:29 PM »
From the McMaster site:
"Grade G-10 Garolite: A glass-cloth laminate with epoxy resin binder offering excellent strength and low water absorption."
"Grade G-10/FR4 Garolite: A glass-cloth laminate with epoxy resin binder, this material is the flame-retardant version of standard G-10 Garolite. It offers excellent strength and low water absorption. "
They list it alongside phenolic/linen composites, but fiberglass isn't linen, and epoxy isn't phenolic.
  • Proverbs
Re: Lucky Boxes II
« Reply #10 on: September 01, 2010, 06:51:48 AM »
I think phenolic has become a misnomer for pretty much all high pressure laminates, or is it just me ?  LOL
 H^^
Allan Perret
AMA 302406
Slidell, Louisiana
Re: Lucky Boxes II
« Reply #11 on: September 01, 2010, 03:30:40 PM »
K & S does make a 5/32 x 5/16 brass tube that would work fine for Lucky boxes.
Don
Re: Lucky Boxes II
« Reply #12 on: September 04, 2010, 02:55:37 PM »
Instead of starting a new post, here is where I am at on the King Sweep.  Don't have picture of flap horn yet.  These are before I started sanding to get it look half way decent. H^^
Re: Lucky Boxes II
« Reply #13 on: September 04, 2010, 03:39:03 PM »
Hi Doc! ;D
Check the amount of "sweep", side to side, the horns make, and if the rectangular tubing will work, it is super easy.  Easier (to me) than fitting two pieces of material above and below the horn and getting the right fit.
BTW:  Using a drill bit and swinging it in an arc where the horns go in the flaps, then flooded with CA will work, too.
Mongo
Re: Lucky Boxes II
« Reply #14 on: September 05, 2010, 08:13:12 AM »
Made the flaps yesterday.  Plywood top and bottom.  Glued one side and then tested.  Hoged out for the flap horn arm sweep and glued other ply peice on.  Pictures later.  H^^
