  • June 19, 2025, 04:05:30 PM
Author Topic: Eliminating vibration in the nose of a profile  (Read 3211 times)
Offline Matt Colan
« on: March 26, 2009, 04:06:34 PM »
Hi
On the first day I went flying (and so far only day) this year and I flew my profile Fw-190.  It has an LA .40 up front and when I flew the tank brackets broke.  My question is this...is there any way I could eliminate vibration in the nose of this plane???  My grandfather already put pieces of duck tape folded over and wedged it in between the tank since there is a space there.
Thanks in advance  H^^
Offline roger
Re: Eliminating vibration in the nose of a profile
« Reply #1 on: March 26, 2009, 04:30:54 PM »
mat
i,m just back in c/l flying after about a 20 yr. hiatus thats all i ever fly is profile ive not had that problum with my planes. always think (bullet proof) these planes are not the rubber band planes they take a lot of abuse up there in landing and stunt operation. if your useing rubber bands to hold a tank on use good hooks screwed into the plywood doublers they should not come undone.
   roger                                                              BULLETT PROOF*
« Reply #2 on: March 26, 2009, 04:44:24 PM »
Matt, pretty hard from a distance to diagnose something like that,, several things to look at though,
first is it really vibrating, or perhaps were the tank brackets not soldered on well?
make sure the prop is balanced
a little ugly to do on a finished profile, but a tripler, (balsa 1/2 inch glued to the inboard side of the nose that will tie in the wing and nose) helps.
changing the mass of the nose will affect the vibration (heavier or lighter) again, not real fun to do with a finished airplane that is correctly balanced.
Change the rpm that the motor runs at, use a different pitch prop so the frequency is in a different range, this could mean using a different diameter prop, or even a different venturi muffler setup to allow it to run right
just some thoughts for you.
Offline Matt Colan
« Reply #3 on: March 26, 2009, 04:59:36 PM »
Mark,  the tank bracket itself broke, not the soldering job.  I guessed it was vibration, because isn't that what would make a tank bracket split right atthe bend???
« Reply #4 on: March 26, 2009, 05:21:17 PM »
Matt,
Could be that the bend radius in the bracket was to small. Can you feel pronounced vibration? Try repositioning the prop 180 degrees and see if it changes. Try mounting the tank with rubber bands. I've done that, but I prefer an aluminum strap clamp to hold my metal tanks, It makes it a bit more difficult to adjust, but they live. Another thing to try is isolating the tank on little standoffs made by slicing fuel line about 1/8 of and inch long. One goes under the bracket, another over the bracket with the screws running through them and a flat washer to keep the tubing from slipping off over the screw heads. I can get you a picture if you'd like to see it.
Offline Matt Colan
« Reply #5 on: March 26, 2009, 07:21:03 PM »
Not until the tank bracket broke.  It has been awhile since I balanced that prop...well I should anyway rebalance it.
This hasn't been the first time the brackets have broken loose, all those times were from the solder joint.  I did originally have a McCoy .35 on it with a 4 ounce tank.  The brackets were positioned long ways on the tank.  I switched to an LA to get more power.  When I switched to this engine, I didn't get a lot of run time, I still don't, but switched to a 4 1/2 ounce tank.  The tank brackets were moved to the top and bottom of the tank and that is when I started getting troubles with the tank brackets coming loose.
Could it be all the holes drilled through the fuse that could be putting stress on the nose be causing it to break loose???
Offline ray copeland
« Reply #6 on: March 26, 2009, 08:01:11 PM »
Randy,,  great idea on the tubing over the tank bracket screws!! First i had heard that..  H^^
« Reply #7 on: March 26, 2009, 08:30:05 PM »
Matt,
How long are the brackets? if they are fairly short, then I would say its probably a result of the configuration that is giving you grief. Especially since you say the problem didnt start till after you switched the setup. what LA are you using,, 40? 46?
On my profiles, I use a 1/16 ply plate that fits behind the whole tank, its epoxied to the back of the tank and has slots milled in it for adjustment. Of course I epoxied it before the tank had any fuel in it so that is not as good foryou since its really hard to get all the oil off. I also put a piece of 1/4 foam behind the tank before I screw it down. I want my tank to be completely supported. If there is any way that it can move, it will and that movement translates to vibration which translates to fatigue at some point in the attachment system. Rubber bands do work, especially if you get creative and setup some sort of "shelf" that you can shim the tank consitantly on, otherwise I find the tank moves around or isnt adjustable both can be problems as you I am sure are aware.
Perhaps one solution would be to solder 4 tabs on the tank, ( yeah I know what a pain right?)  I have also made straps that solder to the back of the tank so they have no bends in them say a peice of thin brass 1/2 inch wide . Perhaps by now you know where the tank needs to be for consitant settings and you could attach it more permantly without needing to adjust it? that would simplify your situation a lot.
Keep up the good work, sounds likeyou are understanding the process and thats a huge part of the solution!
Offline Glen Wearden
« Reply #8 on: March 26, 2009, 08:59:36 PM »
I've had good luck using velcro to attach the tank to the fuselage.  Provides a pretty good vibration cushion and allows easy movement of the tank for adjustment if necessary.  I add rubber bands or zip ties to secure the tank.
Glen Wearden
Glen Wearden
Offline Balsa Butcher
  • High Desert Flier
« Reply #9 on: March 27, 2009, 08:14:57 AM »
I have had the exact thing happen to me on planes where I had fabricated the bracket out of K&S brass stock.  For a while I went back to eyelets and rubber bands but have since switched to the pre-fabricated Brodak tank brackets.  They are inexpensive, well made, adjustable and I have never had one fail due to vibration.  You may want to give them a try.  FWIW I also use a pad of somekind between the fuselage and tank - foam, cork, duct tape, piece of soft balsa, all will work. 8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Matt Colan
« Reply #10 on: March 27, 2009, 10:00:46 AM »
Matt,
I'm running an LA .40.  The reason I changed the setup was to fit a bigger tank on the profile.  That is the only way I could get a 4 1/2 ounce tank on.  I switched because I never got a decent amount of run time with it.  I still now only get about 6 minutes and 15 seconds.  I don't fly the plane in competition anyway, but I flew it because my grandfather forgot the lines to my Smoothie so I had to fly the profile since I have those lines at my house.
Online Jim Kraft
« Reply #11 on: March 27, 2009, 06:10:02 PM »
I have broken tank brackets also. What I do is cut a piece of steel 1" long by 1/4" wide by 1/8" thick, and drill a hole in the middle for the hold down screws. By placing the steel over the brass slotted brackets I can still adjust the tank up or down but have had no problem with the brackets breaking as they clamp the brackets to the fuse. I use the brass threaded inserts for the tank hold down bolts. I also like my tanks mounted as solid as I can get them as I get the best runs this way.
Offline jim gilmore
« Reply #12 on: March 27, 2009, 07:42:41 PM »
To remove vibration in the nose of a profile........
MOUNT THE ENGINE IN THE TAIL!
oK SO I'm 5 days early.......for april fools day...
Offline roger
« Reply #13 on: March 28, 2009, 06:23:23 AM »
 LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~
« Reply #14 on: March 28, 2009, 11:00:14 AM »
Ultimately, it can't be done. You can't eliminate the vibration. You can minimize it and Mark's suggestions are good ones. But you will have to put up with a certain amount of vibration. The trick is to distribute the vibration down the airframe so that it doesn't cause problems. Again, the suggestions here are good ones. Since I'm just finishing up the first profile I've built in a very long time, I guess I'll find out if my approach to dampening vibration is successful. A bit different than what has been suggested. I don't have any plywood doublers.
Offline Larry Fulwider
« Reply #15 on: March 28, 2009, 11:27:54 AM »
Matt –
From this post and others, it is clear you are a very logical problem solver.  y1 Yes, mounting a larger tank on a relatively short nosed profile means that there is no room for end brackets. Using top and bottom brackets is a viable way to go, and there is no reason to abandon that approach. (There are other good solutions, as mentioned above.)
   You didn’t mention how the brackets were fastened to the fuselage. The inherent vibration in a profile nose means that the fasteners need to be darned tight, essentially engine bolt mounting tight. Wood screws or sheet metal screws can work, but often cannot be tightened enough to prevent some loosening due to vibration, which will in turn eventually cause the bracket itself, the tank, or the solder joint to fail. That does not mean that any of those parts themselves are not strong enough.
   As Jim Kraft mentioned above, threaded inserts, although marginal for engine mounting, are quite solid enough for tank mounting in my and others experience. A dab of white glue around the threads and / or at the bolt head / bracket interface also acts somewhat like Loctite (without the permanence) and can serve as a micro vibration dampener. A solid mounting / attachment system, however you choose to accomplish it, is the key to successfully using soldered tank brackets.
   Any of the padding choices mentioned above work. One not mentioned is two sided foam tape, about 1/16” thick. Stick it to the (very clean, lacquer thinner clean) tank, and leave the paper on the fuselage side so it doesn’t stick to the fuselage – leaving the desired adjustment capability intact. (Pics below) With multiple (thicker) layers, remove the protective paper between layers, of course. The tape adhesive is not 100% fuel proof, can get gummy, but stays in place just fine. I like the tape because (a) I have some, and (b) it is easy to use.
Larry Fulwider
Offline Matt Colan
« Reply #16 on: March 28, 2009, 02:30:40 PM »
I did find out the motor was loose also  HB~> when my grandfather went to take a look at it.  That would definitely cause the vibration, I just don't know when that motor started to come loose.  The brackets are Brodak's and are brass.  I didn't put silkspan on the fuse since it was my first kit built airplane and second one ever.
Larry, thanks for the pics on that.  I think I fixed the bracket breaking problem, I just need to give it a few test flights.  H^^
