Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 19, 2025, 04:38:56 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Building techniques
(Moderator:
RandySmith
Eliminating Iron-On Vibration/Humming
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Eliminating Iron-On Vibration/Humming (Read 896 times)
Peter Hess
Trade Count:
0
Lieutenant
on:
November 08, 2010, 12:12:39 PM »
I have two Fancherized Twisters well under way and want to cover the wings with UltraKote. The wings have just a 1/2" x 1/2" leading edge and no sheeting except for the center section and the trailing edge. My past experience is that on this kind of wing iron-on covering will hum unless something is done to reduce or eliminate it.
How do I get rid of that very annoying hum? I have received some suggestions about how to do that but I would welcome any suggestions that you folks might care to make. Thanks in advance for your suggestions.
Logged
Peter Hess
Canton, CT
AMA 485070
Jim Thomerson
Trade Count:
0
Admiral
Re: Eliminating Iron-On Vibration/Humming
Reply #1 on:
November 08, 2010, 01:28:38 PM »
First, cover your Twister wings with silkspan, maybe one thin coat of dope after water shrinking. Then ultracoat over the silkspan to get a rigid puncture proof wing at a very small weight cost. Twister wing needs to have a rigid covering.
Logged
dennis lipsett
Trade Count:
0
Admiral
Reply #2 on:
November 08, 2010, 01:39:10 PM »
put half ribs in between the full ribs. The spacing is really too far for any covering and allows the covering to flex or vibrate. The half ribs will eliminate it.
Dennis
Logged
Peter Hess
Trade Count:
0
Lieutenant
Reply #3 on:
November 08, 2010, 02:44:56 PM »
Jim and Dennis:
Thank you both for your suggestions.
Jim: Would light weight silkspan be sufficient for this purpose or would you suggest medium weight? Your comment about torsional rigidity is well taken.
Dennis: The wings do have half ribs in front of the spars. I gave some thought to adding diagonal half ribs behind the spars as well to give the wings some additional rigidity.
Thanks, again.
Logged
Peter Hess
Canton, CT
AMA 485070
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Building techniques
(Moderator:
RandySmith
