  • August 01, 2025, 09:35:29 AM
Author Topic: Pinning surface  (Read 1275 times)
Offline Glen Wearden
Pinning surface
« on: July 22, 2006, 02:04:19 PM »
I acquired a piece of coroplast used for a temporary sign where my wife works.  Through exlperimentation, it has turned out to be a pretty good surface for pinning parts during construction.  The plastic seems to re-form around the pin and holds it in place.  You must stick the pin through the second layer to keep it from wiggling, but once in place, it stays there.  I placed it on a piece of MDF, which accepted the point, but I didn't have to use a lot of pressure, like that which would be necessary to stick the pin directly into the MDF.  I imagine the coroplast can be bought from a sign maker, as they use it a lot for signs, now.   FWIW  Glen
Glen Wearden
Offline frank carlisle
Re: Pinning surface
« Reply #1 on: July 25, 2006, 06:24:14 PM »
There is an even easier way to get things pinned down Glen............
I have a piece of glass that is 60" X 24".  I glue (instant) blocks of balsa where I want pins to go and then just pin the piece/s I'm working on.
Here is a picture............
Frank Carlisle
