Looking to buy an "ACCURATE" sanding device that would yield absolute accurate 90 degree corners (as in a 6 inch
square piece of 1/8 inch plywood) - hand held device or a super accurate disc sander ? ...... what are you using ?
Thanks in advance.
Geno
EDIT: Sorry, I did something wrong. The photos all appear at the bottom rather than being inserted into the text.
Gene,
It's a little unclear as to what you are trying to accomplish. It sounds like you would like to construct a fuselage jig, and fabricate the parts yourself. In my shop, I have a combination 6" disc and 3" belt sander. The disc sander, with careful use, can create the final dimension on model parts that exceed what our requirements are. It's probably the second most used tool in the shop.
In the first photo, I created a new table base for the disc sander, using a small piece of melamine board. A stringer was epoxied to the bottom of the base to keep it in a constant position. The melamine table does two things for you....it gives you a very smooth surface to work from, and brings the point of the sanding above the center of the disc, where no sanding takes place. This allows one to use the full 6" of the disc surface, realizing of course that the right hand portion will try to lift your work up from the table, so materials have to be held securely, cuts have to be made slowly, and the sandpaper has to be sharp.
Now with the table located on the original surface, you can made a guide which will be an accurate 90 degrees to the disc. I was only making a weight box in this photo, so extreme accuracy wasn't needed. You can use a large piece of wood as the guide, and use more clamps to insure that it doesn't move after you have established the 90 degree angle.
As you can see in the third photo, I was construction a fuselage jig. The accuracy of all of those parts was finalized using the setup on the disc sander.
And the last photo shows the completed fuselage jig, with the accuracy of the "barn doors" established with careful setup and use of the disc sander. This simple tool can easily fabricate dimensional parts that exceed what is needed for our balsa and plywood models and the supporting tools like this fuselage jig.
I hope this is what you were looked for. If not, I just wasted a half hour+ typing when I could have been in the shop doing some sanding of parts. :-)
Lets us know how you make out with your project.
Cheers.
Warren Wagner
