  • June 18, 2025, 12:59:30 PM
Author Topic: Elevator Control Horn  (Read 2771 times)
Online Fred Underwood
« on: May 31, 2016, 06:14:56 PM »
I have a control horn question for the elevator on a profile, about 675 square, 66 oz.  Given a 1/2 inch thick elevator, 1/2" square LE, ribbed, not sheeted, solid block in the horn attachment area with a Standard wire “U” connector.  Will a dowel vertical through the blocks, with a vertical 1/8 wire or with a threaded 4-40 or 6-32 rod be sufficient for long term use.  These are used in RC, but the forces in CL are a bit more abrupt and may be higher.
Fred
352575
Re: Elevator Control Horn
« Reply #1 on: May 31, 2016, 06:40:04 PM »
I have that exact setup on my profile, its a full sized (700 squares) profile, pictures somewhere on here in my impact thread.
I use a hardware setup with a 6-32 bolt and two nylock nuts with an arm from RC stuff. It works pretty good for me
Offline Mike Haverly
« Reply #2 on: May 31, 2016, 08:14:46 PM »
OH BOY!! Show and tell!
I've never trusted that set up.  Probably just fine, but I like the one in my picture.  It's also easier to make the control surfaces removable, which all of mine are.  The turnbuckle is a titanium piece for steering linkage on a car of some kind.  The guy at the hobby shop gave it to me.  It's too long to be practical in a full fuselage but works great here.
« Reply #3 on: May 31, 2016, 09:29:55 PM »
One could make a shorter turnbuckle than that, if one had the right left-hand-thread die.
« Reply #4 on: June 01, 2016, 02:24:03 PM »
The dowel method may not be everyone's first choice for a variety of reasons.  The real question is about long term use in control line at a competitive level.  Not trying to convince anyone to use it, but wonder if is more prone to failure than the more standard type control horn.
Fred
352575
« Reply #5 on: June 01, 2016, 03:56:33 PM »
Yes, Fred I understand.  I led to believe back when I started this stuff again that sticking to the tried and true CL techniques was the way to go.  I have never built or flown any kind of RC so I can't comment on that either.  "Not trusting" is probably just a figure of speech.
